02-18-2010, 12:04 PM | #1 |
HEI Plug Wires
Anyone know what year/model HEI plug wires are long enough to be installed correctly underneath the rams horn manifolds on my '70?
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-18-2010, 12:06 PM | #2 |
Re: HEI Plug Wires
Early 70's Corvette small block should do it as they ran under the block and up to the Plugs. Big Blocks were on top. Al W.
02-18-2010, 12:26 PM | #3 |
Re: HEI Plug Wires
I read somewhere in another thread the 78 corvette worked good.
Tim |
02-18-2010, 12:29 PM | #4 |
Re: HEI Plug Wires
I have been using the universal cut to lenght kits. I like being able to route/fit my wires and then cut them exactly where I want them. They are cheaper to.
Just make sure you get the correct distributor boot/connection for your application ie: male/female etc. Also chose the correct spark plug boot ie: strait/45 angle or 90 degree angle.
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
02-18-2010, 05:59 PM | #5 |
Re: HEI Plug Wires
I got mine from NAPA. They're for a 74-75 corvette, with HEI ingnition. Can't remember the part number. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 02-18-2010 at 11:51 PM. |
02-18-2010, 06:34 PM | #6 |
Firefighter
Re: HEI Plug Wires
1978 chevy pickup uses the same exact wires as the 74 Vette W/HEI, they just have two options above or below exhaust manifolds. Napa Belden #700254.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA Last edited by BLACK AND BLUE 67-72; 02-18-2010 at 06:41 PM. |
02-18-2010, 06:35 PM | #7 |
Re: HEI Plug Wires
HEI was standard I know in '75. Optional in '74 on passenger cars. Just order wires for a 75 'vette and you will be good to go. Those are the wires I run on pretty much anything small block with headers or rams horns.
02-18-2010, 06:44 PM | #8 |
sharp as a marble
Re: HEI Plug Wires
I use a set of Taylor spark plug wire that need to be terminated at the distributor cap end. I do agree that the 78-80 Corvette wires will work, but they are a bit long. The Taylor set can be cut to fit, not really that hard to do, make it easier to run under the motor mounts, if the truck is finished.
Here is a picture or two |
02-18-2010, 06:52 PM | #9 |
User #12137
Re: HEI Plug Wires
http://67-72chevytrucks.com/vboard/s...d.php?t=191592
please take the time to look in the faq section lots of info in there http://67-72chevytrucks.com/vboard/f...splay.php?f=28 |
02-18-2010, 07:39 PM | #10 |
Re: HEI Plug Wires
Thanks for the responses 67Vetteal, Custom 70, Chas 350, OhioDan, Black and Blue 67-72, Mike C and cparman. I appreciate it.
02-19-2010, 11:30 AM | #11 |
Re: HEI Plug Wires
cparman
that looks SWEEET |
12-24-2010, 11:46 PM | #12 |
But Found Her 25yrs Later!
Re: HEI Plug Wires
I've been searching...
This is the most recent thread I could find. I find many auto parts stores don't know if HEI need specific wires for HEI. I know people here keep saying to just use 75-77 corvette, but are all the newer wire sets HEI? The reason I ask is because even the boxes these plugs are in don't say anything like HEI or High Energy.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-25-2010, 12:00 AM | #13 |
Watch out for your cornhole !
Re: HEI Plug Wires
All of the 70s Vette wires the guys above have mentioned are for HEI. GM did away with points and went to electronic ignition on them. Don't muddy the waters with worrying about what the box or parts guys say, they are for HEI. 75 Vette wires will be the ones you want. I run em on all my ramshorns equipped engines.
12-25-2010, 12:05 AM | #14 |
Re: HEI Plug Wires
^Thanks,
I read here, and then expect the parts guys might have even a slight clue. but over and over, repeatedly; these parts store guys are practically clueless. Thanks again and again for this forum.
12-25-2010, 12:43 AM | #15 |
Cruzin
Re: HEI Plug Wires
i believe i will try the cut to fit next time myself i like stuff to be nice an clean
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-25-2010, 12:57 AM | #16 | |
Re: HEI Plug Wires
I have rams horns, so I'm liking the pics here: http://67-72chevytrucks.com/vboard/s...d.php?t=295089
12-25-2010, 12:57 AM | #17 |
laying low
Re: HEI Plug Wires
I like the neatness of the wires routed in the stock location. Kinda hidden. Especially if custom valve covers are used. It is also a good idea to install those heat shields too. Most of us toss them during a rebuild but they are there for a reason.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-26-2011, 07:47 PM | #18 |
Re: HEI Plug Wires
Im bringing this back to the top - the reason is I just got some new wires (early 70"s Vett) and they didnt fit very well - one was about 2 " to short and 2 where way to long. I also tried a 79 GMC 350 - I dont think these where meant for the ram type headers ether
If anyone has newer info on what would fit well for a 350 with the ram type headers please let me know |
12-26-2011, 08:10 PM | #19 |
Re: HEI Plug Wires
I was happy with the cut-to-fit. If I can do it anyone can.
Below is the post from when I did it: http://67-72chevytrucks.com/vboard/s...d.php?t=481155 |
12-26-2011, 08:59 PM | #20 |
Re: HEI Plug Wires
NAPA mileage plus ignition wires part number 2937 for 1976 Corvette will work.
12-26-2011, 09:20 PM | #21 |
Hand Crafted C-10
Re: HEI Plug Wires
I think half the tidy-trick is to use all the right routing brackets...
both on the lower oil pan and the correct looms. Even on an engine stand, routing takes time and don't forget you need a little bit of room to turn your dizzy a tad (timing). The routing in the pics nearly complete but was followed by taking up the slack above the dist cap. Now that I look back, my wires were a little long. BTW-mine were NAPA wires for a '75 Corvette. Five years and no degradation at all. . Last edited by ETsC10; 12-27-2011 at 10:33 PM. Reason: added to post |
12-27-2011, 09:02 AM | #22 |
Re: HEI Plug Wires
Here's how I installed mine. Got the plug wire stands from GMCPaul.
The only diffenece is mine are HEI.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
12-27-2011, 10:08 AM | #23 |
Re: HEI Plug Wires
In '74 the HEI was standard on the L82 Corvette an optional on other GM cars. In '75, the HEI became standard on all V8's. Only the Corvette still used Rams Horns manifolds at this stage with routing underneath manifolds. With minor changes, the wires for any '75-'82 Corvette should be fine.
Length of the wires, or at least how they route, can be varied by which post on the HEI you choose for #1. If one wire is slightly to short and others are slightly too long, the #1 point you have chosen is probably slightly different than the one where GM started. I bought Made For You looms that were designed for the valve covers and bolted them to the oil pan rail to hold/route my wires underneath. Difficult to get some of the aftermarket large boots up through the middle of the motor mount where the original one ran some times. I did the cut-to-fit wires the first few times I did wires 25+ years ago, but now I choose the pre-made for most projects. Saves time, and even with a good set of crimpers, the factory job is better than mine. There are some exceptions with my Jeeps and my Z-car where the factory sets didn't meet my needs. Because of firewall clearance on my Jimmy I ran a Ready-to-Run MSD distributor that uses a points style cap so I just bought the Taylor pre-made '72 Chevy truck wire. But you can use '71-'73 'Vette wires as well. Stay away from ordering '74 wires because once again, now all of them had HEI.
12-27-2011, 11:02 AM | #24 |
Who's got steelies?
Re: HEI Plug Wires
The Corvette wires do work, but some will be a bit too short if you're using the factory 67-70 wire loom brackets, because they route the wires high up away from the engine to clear the accelerator rod. I bet they fit stock 71-72 factory plug wire brackets better because of the switch to an accelerator cable, and the Corvette with ramshorns probably has the same brackets.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
12-27-2011, 02:14 PM | #25 |
Re: HEI Plug Wires
thanks guys - Im hoping I just had a bad set - Napa is closed for the week and Pepboys don't dont have them in stock. So Im stuck with Oreilly. We'll see how they fit.
