02-21-2010, 03:04 PM | #1 |
'99 suburban lower ball joint.
hi my 99 gmc suburban needs new ball joints. im working on the drivers side now and i have the old upper ball joint out and the new one in. im having a problem with the old lower ball joint, can anyone help me out and let me know the way to remove it? thank you
03-02-2010, 11:14 PM | #2 |
Re: '99 suburban lower ball joint.
A ball joint press is the best bet. It looks like a huge c-clamp but has adaptors to fit over the stud and press the ball joint into. Or you can remove the arm and put it into a hydraulic press. These ball joints are pressed in. I bought the ball joint service tool from HF and did my 99 suburban with the arms on the vehicle.
03-05-2010, 08:08 AM | #3 |
some are pressed in some are rivited in.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-05-2010, 09:14 AM | #4 |
I just replaced mine. I couldnt get my lower ball joints out with the ball joint press. I eventally took the arms off and had them pressed out.
03-05-2010, 05:37 PM | #5 |
I remove them with a big hammer.
10-13-2013, 09:09 AM | #6 |
Is this the same as doing it on a 4x4 with torsion bars... I just don't know if they will release or something
2004 Silverado Crewcab (Dark Spiral Gray) |
10-20-2013, 07:42 PM | #7 |
I did mine with no problems other than having to make a shorter adapter to be able to get them pressed back in. I really recommend a ball joint press to get them in and out...
