Old 03-06-2010, 12:48 AM   #1
OrrieG
OrrieG's Avatar
Windshield squirter
I cleaned up my wiper bezels and noticed they have the tube for a squirter. What is everyone using for aftermarket squirters with the pumps on the tank? Any good junk yard prospects? I am running a 59 GMC electric motor with no provision for the motor mounted type. Thanks Patrick
OrrieG is offline   Reply With Quote
Old 03-06-2010, 08:04 PM   #2
OrrieG
OrrieG's Avatar
Re: Windshield squirter
Guess nobody else drives their trucks in the rain....
Old 03-07-2010, 02:32 AM   #3
Dan Bowles
AD Addict
If it's raining, they don't need the squirter! They are already wet.
I wonder if the '54 bel air bezels will go on my '54 pick up to give me the option...for ifn I drive in the snow.
Dan Bowles is offline   Reply With Quote
Old 03-07-2010, 03:44 PM   #4
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
I tend not to drive my old truck when its raining. While it does not have squirters its got more to do with the wiper speed. It often rains just a little here and you really need intermittent wipers. So I drive something newer that had those and don't think much about squirters.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 03-07-2010, 04:29 PM   #5
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
I'd say just about any car at the junk yard with the squirter motor built into the tank will work, Just wire it, mount it, and plumb it.
addicted2dunes is offline   Reply With Quote
Old 03-07-2010, 07:07 PM   #6
OrrieG
OrrieG's Avatar
Thanks for the comments, I'll just nose around next time I hit the junk yard.
Old 04-30-2010, 10:49 PM   #7
renegade6
I purchased a pump from Newport Wipers. I plan on using one of the stainless surge tanks as my windshield washer reservoir.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 05-01-2010, 02:37 PM   #8
Atomsplitter
Atomsplitter's Avatar
I picked up a Princess Auto washer tank/pump combo for about $10. It comes with a mounting bracket so you can put it on the firewall.
Just need to install it!
Anyone mount nozzles in thier hood...what kind did you use?
Atomsplitter is offline   Reply With Quote
Old 05-01-2010, 06:05 PM   #9
poncho_villa
poncho_villa's Avatar
A previous owner installed a reservoir with the electric pump. The plastic now has a crack and leaks from a poor install, and I hope to repair it with a bit of silicone caulking. No idea what vehicle was the donor tho. I installed a spring loaded button on the dash to activate the squirter. Yup, junk yard would be your best bet.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 05-02-2010, 02:07 PM   #10
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
The one out of a 85-87 chevy should work, its got the pump on the back side of the tank, but i think a lot of newer (well newer than 87) chevys have pretty much the same setup too.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 05-02-2010, 05:33 PM   #11
OrrieG
OrrieG's Avatar
Thanks for all the replys, now I just need to get to the junk yard.
Old 05-02-2010, 08:04 PM   #12
5150
C10 Club Tennessee
5150's Avatar
On my old 70 stepside, I got one out of a S-10. Make sure you get the grommet also. Then just drill a hole in your washer tank and install it. It has to be at the bottom of the tank. Then wire it up and your set.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
