Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-09-2010, 02:36 PM   #1
53GMC
53GMC's Avatar
How to Adjust Shifter linkage?
hey guys....how do i adjust the shifter linkage on a 1996 column shift S10....it real tough to shift it all the way down into drive and the lever pulls down almost all the way before it reaches drive...runs out of room to shift before it reaches 2 or 3...think it is because my linkage is a little crazy off and may be too loose since I just recently installed another steering column... help?
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 03-09-2010, 07:20 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: How to Adjust Shifter linkage?
disconnect linkage from tranny arm, place column lever in "N", have buddy hold it there against the "D" stop, install linkage to tranny, test.
68C15 is offline   Reply With Quote
Old 03-11-2010, 10:51 AM   #3
53GMC
53GMC's Avatar
ok...after i place the column lever in N, just have my buddy hold it in N While i connect the cable back to the tranny arm which is in what gear?
Column lever in N connects to tranny arm in which gear?
1953 GMC/S 10 Swap
Old 03-11-2010, 02:38 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
place the tranny in N as well. start at park (on tranny) and rotate until it notches to N. easy way to tell P is that the distance from P to R is wider than any others. like this
P--R-N-D-3-2-1
have buddy hold lever down against the N stop (but not letting it drop into D)
just remembered, P is all the way forward at the tranny arm.
Old 03-11-2010, 02:41 PM   #5
53GMC
53GMC's Avatar
ok....thank you for your help 68C15....I will definetely give that a shot to see if i can get that to fix my problem....
thanks again!
53GMC
1953 GMC/S 10 Swap
