Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-14-2010, 07:00 PM   #1
Nick's81
Nick's81's Avatar
Welded rear
how about some feed back on welding my carrier for track use, have done it several times on my rock crawlers WITH good success, just cant aford a possy yet (wife & kids) just kicking it around. oh 64 with stock 12bolt 3.73 gears, 300hp 327 th350 26.5 x 8 hossiers treaded
Nick's81 is offline   Reply With Quote
Old 03-14-2010, 07:24 PM   #2
tomtuna1978
Re: Welded rear
why ??? is this truck just used for the strip ? if not ... id say no ! you dont have enuff power to warrent it ! and there will be more problems than its worth !
tomtuna1978 is offline   Reply With Quote
Old 03-14-2010, 08:36 PM   #3
djracer
djracer's Avatar
Re: Welded rear
Are you only gonna race it? If so go for it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-14-2010, 09:25 PM   #4
wheatlandbrawler
wheatlandbrawler's Avatar
Re: Welded rear
im with dj... race only? GO FOR IT. just remember if if it breaks something it will most likely break more then it originally would so it may cost you in the long run. but for a budget racer i say DO IT.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 03-15-2010, 12:27 AM   #5
Nick's81
Nick's81's Avatar
Re: Welded rear
as for breakage its the original 12bolt small axle gives me a excuse to tell wife i need to find a 9in. ? how strong are the stock axles 27 -30 spline? had same engine in my toyota with a 700r4 and welder toy axles yess i know toy axles are stronger than my 12 bolt and i did drive my toy every day so i am aware if the quirks
Old 03-15-2010, 02:02 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Welded rear
NHRA has a rule against it, (for good reason) and if your caught don't be surprised if your black ball'd from the track. Tech really hates when you slip something by them unseen. First line of General Reg 2:11
WELDED SPIDER GEAR REAR ENDS PROHIBITED IN ALL CLASSES
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-15-2010, 03:56 PM   #7
cableguy0
Re: Welded rear
Yes welded spiders will work. I understand the budget thing but when you weld those spiders you turn the rear into a bomb. Its not a question of if it will break its just when. Btw a 12 bolt will hold up to most of what you can throw at it.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-15-2010, 07:07 PM   #8
ProStreet71
Re: Welded rear
I tried it once and grenaded the rearend first time out, wont be doin that again. Broke my posi unit one weekend and was in hurry to get back to track and just threw in an old carrier I had laying around so I couold get back on the track the following weekend. In hind sight, I shoulda just waited for my new unit to arrive.
ProStreet71 is offline   Reply With Quote
Old 03-15-2010, 07:21 PM   #9
71chevytruckguy
71chevytruckguy's Avatar
Re: Welded rear
I say DON'T WELD them. They will break and you'll go down the track on 3 wheels. If anything, buY a mini-spool. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 03-15-2010, 08:26 PM   #10
onlyifihadachevy
Re: Welded rear
My advise is not to because the rear wheels feel like they want to hop, and feel unstable. And if they don't allow it why risk it.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-15-2010, 08:37 PM   #11
turbo350
Re: Welded rear
If you weld it keep the wife and kids out of it for sure.
turbo350 is offline   Reply With Quote
Old 03-16-2010, 12:40 AM   #12
85_prairieboy
85_prairieboy's Avatar
Re: Welded rear
Go for it!
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 03-16-2010, 02:14 AM   #13
wheatlandbrawler
Re: Welded rear
when it blows through a 9 inch in it with a mini spool thats the most COST EFFECTIVE means.
Old 03-16-2010, 07:47 AM   #14
djracer
djracer's Avatar
Re: Welded rear
Originally Posted by 85_prairieboy View Post
This is not even gonna pull off. If you do weld it you weld the spider gears not the ring and pinion.
I'll check on a mini spool and see if I can get it less than JEG'S. THEY ARE 132.99
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-16-2010, 08:15 AM   #15
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Welded rear
Thats funny??? How do you put that welded ring and pinion in??
Kev if you find a deal on the mini let me know too...I'm going to have a traction problem and your going to need a wider rear bumper so I can draft at the track....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-16-2010, 08:17 AM   #16
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Re: Welded rear
X2, that setup will never work. I got a mini spool for my 10 bolt in my little truck for $89.00 at the Hot Rod Barn down in town. I busted the transmission off the motor and twisted the driveshaft once coming off the light but have never broke the rearend.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 03-16-2010, 09:45 AM   #17
85_prairieboy
Re: Welded rear
Lol at least you don't have to worry about setting the backlash. Haha its just a picture I found on the web. It made me laugh. And no I do not recommend welding a diff. I did it once and thought I was a hero until a year later when it let go and a chunk got wedged between the ring and pinion and locked up the rear wheels.
1980 Z28 Camaro
Old 04-18-2010, 06:23 PM   #18
Nick's81
Nick's81's Avatar
Re: Welded rear
well went to the track fri. night my best 60ft 2.203 could not hook up kept spinning tire, then it would hook and spin left tire still thinking about welding the rear
Old 04-18-2010, 07:46 PM   #19
shortbed70
shortbed70's Avatar
Re: Welded rear
Mini spool in 30 sline axles will hold up under moderate power for dd I drove my 65 for a year on the street and highway with now wear on the axles and It only cost me $80 off ebay.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-18-2010, 11:29 PM   #20
Nick's81
Nick's81's Avatar
Re: Welded rear
did you need c-clip eliminaters i've found a 9in on cl ill be getting and mini spool from summit less than 50 but would like to play till i get it
Old 04-18-2010, 11:46 PM   #21
shortbed70
shortbed70's Avatar
Re: Welded rear
Nope was alittle tricky but it will fit
Troy
Big Red Dog build
Old 04-19-2010, 01:21 AM   #22
Ron 586
RIP Mr Ron
Ron 586's Avatar
Re: Welded rear
I have ran welded up 8.5 10 bolt rears for years with out fail. Engines were 400 sbc and 355 sbc. All were turbo 350 trans with a shift kit. Cars were 78 and 81 camaro's and 79 nova. All were footbrake cars with B&M 3000 rpm and ACC 3500 rpm converters. I was a poor boy that wanted to play so that is the corner that I cut.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 04-19-2010, 09:06 AM   #23
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Welded rear
Actaully, welding the pinion to the ring WILL work. After the great depression, we used to use rear ends as props on our planes when the original ones would break. The Japanese Kamikaze planes used this trick as well to keep the overall cost down of the planes that would not be coming back!!
prostreetC-10 is offline   Reply With Quote
Old 04-22-2010, 07:17 PM   #24
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Welded rear
if you weld it dont weld the spider gears together
weld the gears that attach to the axle to the carrier it will be much stronger
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 04-22-2010, 09:51 PM   #25
ERASER5
ERASER5's Avatar
Re: Welded rear
Originally Posted by prostreetc-10 View Post
actaully, welding the pinion to the ring will work. After the great depression, we used to use rear ends as props on our planes when the original ones would break. The japanese kamikaze planes used this trick as well to keep the overall cost down of the planes that would not be coming back!!
snork!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
