Old 03-21-2010, 08:09 PM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
#15, a 64 gmc
my newest acquisition... a 64 gmc 3/4 ton.
I had asked the neighbors kids about this 3 years ago, and they said it was thier uncles, fast forward 3 years and the uncle came back to town, they remembered to tell him I asked about it(!?), and he stopped by and sold it to me!
this one has just a mint tailgate, and the box is a 9 out of 10, it had a camper in it for 20+ years.
It has a 425 caddy and an automatic jammed in it, and it "ran when parked" in 1996, and then again in 2002.
I will need to fix a few things with the ignition harness, and the fuel system, but it looks like it might be a runner.
probably the main reason I was interested was the factory spotlight, that will fil the hole on my 65 dd. another bonus was the "city chevrolet" emblem from a great falls dealer that is also missing off my dd.
at some point he had hit a deer, and put a chevy front clip on it, and it has a real nice hood.
$200!!
Old 03-21-2010, 08:15 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: #15, a 64 gmc
Any close up pics of the spotlight! Is the glovebox door melting?
Old 03-21-2010, 08:24 PM   #3
jonzcustomshop
1961 crewcab
Re: #15, a 64 gmc
are these stock for a gmc? I have another gmc with the same mirror bracket, and the sunvisors seem stock...
check out the notch they cut into the crossmember to jam that caddy in there, the cut a couple holes into the firewall as well
...and the rusty rockers were "fixed" with what looks to be 2x2 square tubing.
Old 03-21-2010, 08:27 PM   #4
jonzcustomshop
1961 crewcab
Re: #15, a 64 gmc
funny! it has some of that thick outdoor furniture marble paint on it...
you know I guess I didn't take a pic of the light or bracket yet, I will get one next time I am out at the truck.
Old 03-21-2010, 08:35 PM   #5
DPowers
DPowers's Avatar
Re: #15, a 64 gmc
WOW- Can't beat the price.
DPowers is offline   Reply With Quote
Old 03-21-2010, 08:37 PM   #6
protrash64
Resistance is Futile
protrash64's Avatar
Re: #15, a 64 gmc
I just saw a 425/400 combo on C/L today and saw the front sump oil pan. That would explain the notch. Quite a collection you're building.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-21-2010, 09:20 PM   #7
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: #15, a 64 gmc
Nice custom speaker job you got on there. And for some reason I think they mounted the carb in the wrong place. But seeing the rest of the truck I could be wrong.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-21-2010, 10:36 PM   #8
jonzcustomshop
1961 crewcab
Re: #15, a 64 gmc
you should see the fuel lines, I could probably mount that extra carb where it sits....
the seat, and tilt/teloscopic column are probably out of the same caddy the engine and trans came out of...
Old 03-21-2010, 11:59 PM   #9
protrash64
protrash64's Avatar
Re: #15, a 64 gmc
I go to too much work to mount mine; I forgot they would stick by themselves!
Old 03-22-2010, 12:01 AM   #10
ruffrida2005
Re: #15, a 64 gmc
looks like they have straps on it. I be they dont have very much bass.
Paul
Old 03-22-2010, 08:13 AM   #11
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: #15, a 64 gmc
Awesome Parts truck Jon
IIRC the sunvisors had no clips (but those look good there)
The mirror head might be correct but the bracket is definitely not
Good score on the tailgate,that's sweet lookin'
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 05-08-2010, 08:06 AM   #12
jonzcustomshop
1961 crewcab
Re: #15, a 64 gmc
here is a pic of the spotlight, it said unity on the light housing, and the lamp and housing is quite small.
Old 05-08-2010, 12:44 PM   #13
markeb01
Senior Enthusiast
markeb01's Avatar
Re: #15, a 64 gmc
Thanks for sharing your photos. Not sure how you get anything done with so much to pick from. Nice score on the spotlight, particularly if you need one for your other truck. It's probably an S5 (5" bulb) instead of the more common S6 version. So much straight sheet metal for such a small price, of course that crossmember looks a bit scary.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-08-2010, 03:08 PM   #14
andyh1956
Re: #15, a 64 gmc
hey, is that a "pinto" shifter in the floor? that used to be the most common way to make a swapped in auto shift.
andy
andyh1956 is offline   Reply With Quote
