Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-26-2010, 07:40 PM   #1
72gmcshorty
72gmcshorty's Avatar
How to mount radio??
I am going to install an aftermarket deck into my 92 gmc. I have removed the old tape deck and radio. I have the outer trim piece (with the vents) but was wondering what i mount the actual radio to? Am i missing another piece?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 03-28-2010, 09:09 AM   #2
dirtyd_nd
Re: How to mount radio??
There are two different types that I have seen. One the radio will have a sleeve that slides off for mounting in the dash kit. It will lock on so you will have to read the directions for it to see how to unhook it. Once it is off you slide the sleeve into the dash kit and bend the tabs up to mount it to the kit. Then the radio slides back in and locks in place. Or the radio will have small screw holes on the side that line up with the dash kit sides. All parts needed usually come with the dash kit/radio. Hope that makes sense to ya.
Dale
dirtyd_nd is offline   Reply With Quote
Old 03-28-2010, 06:05 PM   #3
72gmcshorty
ya, i put the sleeve into the trim and bent the tabs. Just wondering what i can do to secure the radio in there a little better. maybe screw it down to the bracket in cubby space?
1992 Gmc 2wd
