03-29-2010, 07:32 AM | #1 |
rockers and bed side patch
ok i have to order rockers and lower rear bed side panels who does everyone recomend maybe a company that supports the forum
03-29-2010, 09:49 AM | #2 |
Re: rockers and bed side patch
Ordered mine from Mike's Bump and Grind Garage (mbgmike). Nice parts and good prices. You can click on the link in my signature for the list of board vendors. Hope this helps!
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
03-29-2010, 10:06 AM | #3 |
425hp409
I bought rockers from LMC and the fit was horrible. My bodyman cut out the drivers side and worked a long time to make the new one fit, finally settling for a so-so fit. He then repaired the right side with a patch panel so that it would look good. Most people would not notice the poor fit unless you pointed it out to them, but I look at it every time I see the truck!!! Keep your originals if at all possible unless someone has a better source.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
03-29-2010, 10:14 PM | #4 |
went with mikes bump and grind ended up ordering way more then i wanted cause he had such good shipping rates also really easy to talk to
