04-07-2010, 01:11 PM | #1 |
El Chingon
Decided to share the work so far on the chassis,
step notch for the rear. step notch for the front. |
05-06-2010, 11:12 PM | #2 |
Re: El Chingon
Porterbuilt bag plates being installed, he gives you the bolt holes for the sway bar for the alignment. Then i used a transfer punch to align the rest once i bolted it with the sway bar holes. Then just drill and bolt it all up. |
05-06-2010, 11:35 PM | #3 |
Re: El Chingon
PB dropmember that is going in. |
05-07-2010, 11:26 AM | #4 |
Moderator
Re: El Chingon
Love the work....love the project name even more
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-07-2010, 11:44 AM | #5 |
Re: El Chingon
good progress, where are you going to mount the rear bags?
View pics of my truck - 1968 Chevy C10 SWB - Photobucket I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
05-07-2010, 02:41 PM | #6 |
Re: El Chingon
bag mounts run along the front of t he notch, i will post more pics of the rear frame later tonight. the rear section is not completely finished.
05-07-2010, 03:40 PM | #7 |
Junior Member
Re: El Chingon
nice
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
05-07-2010, 07:09 PM | #8 |
Re: El Chingon
its gonna be nice bro.
05-08-2010, 10:23 PM | #9 |
Re: El Chingon
pics of the rear section with all the bag mounts, shock mounts and panhard bar mounts. pic of the front porterbuilt notches welded in and smoothed. |
07-26-2010, 08:59 PM | #10 |
Re: El Chingon
update: just got the frame and porterbuilt parts back from powdercoating. It was raining in houston so the frame already got its first wash.
07-26-2010, 09:06 PM | #11 |
Re: El Chingon
If you want to get parts powdercoated in houston this is the place to go. I took them a total of 38 pieces:
Frame, rearend housing, complete front porterbuilt package, upper and lower control arms, bag plates, valve mounting brackets, u bolt and mounting plates for rear, panhard bar, trailing arms, trailing arm crossmember, air tank, and a bunch of mounting brackets and tabs. 800.00. no tax. cash. The color option was any color as long as it was black. It is a polyester tgic powder i think he called it. I hope it was the right stuff for the application. |
07-26-2010, 09:08 PM | #12 |
Re: El Chingon
Few more pics:
07-27-2010, 10:51 PM | #13 |
Re: El Chingon
Got the trailing arm crossmember together tonight, i used 7/16 bolts instead of 3/8. It seemed that the 7/16 bolts took up more slack in the hole then 3/8, it was not for strength.
07-29-2010, 10:18 PM | #14 |
Re: El Chingon
well since you asked:
07-29-2010, 10:21 PM | #15 |
Re: El Chingon
i used kp components axle kit for the bag brackets and shock brackets. the bag plates for the a arms are from porterbuilt. i stitched up the trailing arms every 8 inches or so with the welder to keep them from seperating. i wish it would stop raining here in houston so i can start throwing parts on the frame......
07-29-2010, 10:28 PM | #16 |
Re: El Chingon
no rain and 100 degrees all weekend!! get that frame done,lol
07-29-2010, 10:32 PM | #17 |
Sofa King Crazy!!
Re: El Chingon
I hear ya, the rain is gettin old around here. Almost everyday for over 2 weeks! Your frame and other parts look great, they did a really good job on the powder coating. What part of H-Town are you in?
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
07-29-2010, 10:42 PM | #18 |
Re: El Chingon
I am in N.W houston, 610 and 290 intersection. Yea, i am dropping the diff off at pyle bros. tommorrow to get assembled. It will go together real fast once i get the diff. back. I still need to install the a arm bushings i got from energy, i am actually scared to do this and hope i dont chip the arms installing them.
07-29-2010, 10:56 PM | #19 | |
Sofa King Crazy!!
Re: El Chingon
07-29-2010, 10:59 PM | #20 |
Re: El Chingon
i used to work out of 1960 and 290, a go kart/bicycle shop called Davids Cycles. I like the area, one day i will move out of the hood.
07-29-2010, 11:07 PM | #21 |
Sofa King Crazy!!
Re: El Chingon
Hahahaha. Yeah David Cycles by Sterling Body Shop, not to far from the shop. Closest intersection to us is Cypress North Houston and Eldridge. I grew up in the Heights when it was the hood. Keep the pics rollin, I may get some good ideas!!!!
07-30-2010, 08:58 PM | #22 |
Re: El Chingon
got the upper and lower control arms together, the lowers were a pita, one was a little tweaked so i had to get the porta power out and do work. show ya guys some assembly.
07-30-2010, 09:08 PM | #23 |
Re: El Chingon
well one picture will not come up, it shows where i sanded the powder off of the end the bushing rides on. it is pretty straight foward on the uppers, i will not even show what i had to do to get the lowers in.
07-30-2010, 09:22 PM | #24 |
Re: El Chingon
lowers:
08-01-2010, 10:34 PM | #25 |
Re: El Chingon
got the bushings from summit racing, they are from energy suspensions. the are the poly. bushings. i hope they dont make noise when it is all said and done. i coated them with the grease that comes with them, price was to good to pass up over the rubber ones.
