Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-18-2010, 02:55 PM   #1
chevyboy55
chevyboy55's Avatar
Rear Speakers are REAL quiet
As the title says the rear speakers are putting out very little volume. When you turn the fader to rear you can just barely hear any volume. the speakers don't rattle & crack like they are blown out, they just have little volume. The head unit is a Kenwood KDC X592 it has a 1000 watt amp (don't remember the brand & 2 10" subs, don't remember the brand but I think they are JBL. they are under the seat & I don't want to pull it out just to see) the speakers(dash & 6"x9"s) are Infinity's. The subs & dash speaker work fine, just the rears are low volume. I checked to make sure they are connected, they are. Any ideas of where to start looking? Mike
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 04-19-2010, 02:41 AM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: Rear Speakers are REAL quiet
Check the gains adjustment and also the low-pass filter. Try turning the gains up a bit and also set the LPF to about 150hz
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 04-19-2010, 07:19 PM   #3
chevyboy55
chevyboy55's Avatar
Ace. I'm a stereo dunce, I assume these are on the amp correct? Also where would I find the low pass filter?
Old 04-20-2010, 05:58 AM   #4
AceX
>130dB Moderator
AceX's Avatar
Sorry, all the adjustments should be on the input side of the amp. Each adjustment should be labeled with a min/max or #
Living Life @ 130dB
RIP El Jay
Old 04-21-2010, 09:32 PM   #5
chevyboy55
chevyboy55's Avatar
I will tackle that this weekend(have to pull the bench seat out to do it) when I have the seat out what should the other settings be?
