Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-18-2010, 09:57 PM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
abs brakes help
looks like the abs has went out in my 91 gmc s15 jimmy 2wd.
thought the master cylinder went out but it is the abs.
anyway, can anyone give me any help on bypassing the abs unit which ones do i need to tie togther and where do i get the fittings.
there are 2 lines going to the Proportion Valve, and 2 coming out and going to the abs.
then from the abs, theres 2 going to the front wheels, and one going to the rearwheels. that makes 5 total in the abs.3 lines for the front, and 2 lines for the back. i know atleast 1 line is a different size from the others, but not sure
of the sizes yet. would an autozone or a carquest have any thing to make this work?
THANKS
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 04-19-2010, 08:25 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: abs brakes help
Here you go, I think someone will get you over here.
And you can take it all the way out, but you will have to do some brake line work under the hood.
Trav..
tvblazer78 is offline   Reply With Quote
Old 04-21-2010, 06:48 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: abs brakes help
sounds like someone pushed caliper pistons in without opening bleeders forcing sludgy fluid up into the ABS unit which causes the isolation and dump valves to stick open.
think of it like this; would you rather sit on the toilet and have the poo go out or rather use the plunger handle and shove it up further towards you intestine?
it can be bypassed. the front lines will need a "T" while the rears will need a coupler union. do NOT use compression fittings of any sort at all. inverted flare only NAPA should have all the adaptor fittings to make it work. it'll take a few trips to get all the stuff, take your time
68C15 is offline   Reply With Quote
Old 04-22-2010, 01:47 PM   #4
Damien
Damien's Avatar
Re: abs brakes help
There are some pictures that kinda show my master cyl. in my build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=385888
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
