Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-20-2010, 12:15 PM   #1
383 Stroker
383 Stroker's Avatar
Fuel System Help
Does anyone see anything wrong with my fuel system? I have 10an to the pump, then 10an from the pump to 5/8" aluminum line all the way the the regulator. 8an from the regulator to the carb. 6an from the regulator the the nitrous solenoid. I'm having problems with it laying over starting around 5000rpm... The fuel pump is a edelbrock 160gph and edelbrock regulator.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 04-20-2010, 12:17 PM   #2
383 Stroker
Re: Fuel System Help
More pictures
Old 04-20-2010, 06:54 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Are you pulling timing out for the giggle gas? are you using plenty of octane for the enrichment fuel? Stepping plugs 1 step colder (than optimum for n/a ) for every 50HP of N2o?
I'm not a fan of the Edelbrock pumps, and DEFINATELY not a fan of deadheading a N2o system. But plenty do it and get by so what do I know,, I gave up the giggles over a decade ago. Lot's has changed since then.
One thing I do see that would never get by tech here,, the cell MUST have a metal (0.023 steel or 0.060 aluminum as I recall) shield on ANY portion of a poly cell exposed below the floor (trunk / bed or whatever).
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
