Old 04-20-2010, 06:55 PM   #1
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
95-98 dash crack? Repair or replace?
Would you repair or replace this crack in the dash?
If repair, how so?
If replace, can I just replace that "section" or is it the entire dash that has to be replaced? Either way, how hard is it gonna be?
Might just have to find a dash mat for the time being.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 04-20-2010, 07:39 PM   #2
scotts62
One day...
scotts62's Avatar
Re: 95-98 dash crack? Repair or replace?
Mine was cracked in the same spot from a thief.. i was going to fiberglass it and paint it just because that panel is really expensive new unless you can find a good used one cheap.
Scott
93 crew cab build
Project 62
Old 04-20-2010, 07:54 PM   #3
BIGphillip79
BIGphillip79's Avatar
Doesn't look too bad, I would just get one of those custom fit dash covers.
If it ain't broke broke don't fix? Get a hammer.
'89 K1500, Reg. cab/long bed, 350/700r4, 285/75-16.
BIGphillip79 is offline   Reply With Quote
Old 04-20-2010, 07:55 PM   #4
wancosc356
wancosc356's Avatar
Yeah. I wouldn't buy a new one. I would look for a used one. So that panel is removable without having to remove the entire dash?
Yeah. Its not terrible. Ill get a dash mat either way.
Michael
Old 04-20-2010, 08:29 PM   #5
1badgmc
1badgmc's Avatar
That crack is on the main dash piece. The whole thing would have to come out to replace that. I haven't pulled a late-OBS dash, but I did pull and replace the dash in my '91. That was NOT a fun job by any stretch of the imagination!
Old 04-20-2010, 08:40 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I'm thinking that Just Dashes would be a good resource, but they don't offer a cover for the 95-98's. It may be because the dash change in '95 and again in '97. So, there may be something to the idea of using fiberglass to skim the original, and then paint it. It's gotta be cheaper than going for an OEM dash pad that may be just as brittle.
I guess our trucks are in that cusp of years that the aftermarket hasn't decided to accomodate in a total manner. Some stuff is out there, but not all.
Member Nr. 2770
Old 04-20-2010, 09:54 PM   #7
wancosc356
wancosc356's Avatar
Thats what I thought. Haha. Super glue or duct tape??? I can live with a small crack...for now.
I didn't know the dashes changed again in 97. Thanks for the tip. May look into the fiberglass deal.
Michael
Old 04-20-2010, 10:18 PM   #8
1badgmc
1badgmc's Avatar
Thought so.
You have the '88-'94 dashes that are the same throughout aside from different gauge clusters and radios, but all the actual dash pieces are the same. In '95 you got the updated interiors. That dash lasted for 2 years; '95 and '96. In '97 the trucks got passenger side airbags, so the dash got reworked on the passenger side of the bezel.
Old 04-20-2010, 10:35 PM   #9
wancosc356
wancosc356's Avatar
Oh I see. Thanks!
Michael
Old 04-20-2010, 10:39 PM   #10
bwood
bwood's Avatar
Mines cracked from just below that all the way to the VIN panel and throughout the defroster vent. Last time I checked, the new dash was $1k unpainted from the dealer.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 04-20-2010, 10:42 PM   #11
wancosc356
wancosc356's Avatar
Ouch! This is what my conversation with the parts guy would have looked like...
Haha. That is just nuts!
Michael
Old 04-20-2010, 10:46 PM   #12
bwood
bwood's Avatar
There is a wrecking yard near by that ended up with a bunch of clunker trucks. I'm going to see if I can find a better one?
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 04-20-2010, 11:15 PM   #13
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I would just put a dash mat on it and call it good! I am sure that a whole new dash will be insanely expensive to say the least.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-20-2010, 11:22 PM   #14
bwood
bwood's Avatar
I would, except it is feels loose and makes noise going down the road.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 04-20-2010, 11:33 PM   #15
1971gmcshortbed
1971gmcshortbed's Avatar
It will be difficult to find a used good one. If they aren't careful taking it out it can break, old = brittle. I would leave it alone. It comes out with the bulkhead/harness, the harness that goes into the engine. About 8 hours worth.
1971gmcshortbed is offline   Reply With Quote
Old 04-21-2010, 12:57 AM   #16
Rimshot1911
Rimshot1911's Avatar
I would put some super glue under the crack and then once it dried use a heat gun/hair drier and the color should come back. Solves the ugly hole and the color won't change too much. Just my .02 worth.
"Live free or die" LaRue Tactical
"Just think. Someone worked hard to make it look that bad." 1badgmc
1997 C1500 V6 Reg Cab Short Bed
Rimshot1911 is offline   Reply With Quote
Old 04-21-2010, 01:20 AM   #17
wancosc356
wancosc356's Avatar
Thanks fellas. Dash mat it is! Anyone got an extra laying around?
Michael
Old 04-21-2010, 07:29 AM   #18
BigBlocksRule
Pull the gauge/control surround piece, that'll give you better access to that area. It might help to pull the gauge cluster for better access. Get some sort of small clamp - something with decent width jaws that will allow you to clamp directly across the crack, I've used Stanley Quick Clamps. JB Chemweld dries to almost the same color as your dash. Mix it up and make sure you get some in the crack, may have to use a toothpick. Smash it together as much as you can with your fingers, then wipe off the excess that runs out of the crack on top. Clamp it - use wax paper to keep it from sticking to the clamp - and let it set overnight. When you pull the clamp off, mix up a little more and apply it across the crack on the underside to give it a little more strength.
Done, costs less than $10 and you won't have to mess with the nightmare of removing and replacing that dash. Believe me, that's something you don't want to mess with if you can avoid it.
I know a guy who busted a connecting rod in his numbers matching 454 in his Chevelle. It knocked a clean chunk of metal out about the size of a 50-cent piece. He had everything cleaned, then JB Chemwelded the piece back in place. It's been at least 10 years since he did this and it's still running 11's.
BigBlocksRule is offline   Reply With Quote
Old 04-25-2010, 08:24 PM   #19
wancosc356
wancosc356's Avatar
Thanks for the advice BigBlocksRule.
Well my dash is the 95/96 style, but.....
I found a guy selling a 97/98 style dash in very nice shape and the same grey color to boot. Includes gauge cluster, radio, heater controls and passenger air bag. He also has a steering column with the steering wheel with the airbag too.
So my questions are:
What it is all worth, so I can know what to offer?
And will it mount right in place of 95/96 dash? If so, can I hook up the airbags easily or should I even bother? Looking for experience and suggestions here.
Michael
Old 04-25-2010, 08:47 PM   #20
BigBlocksRule
I bought two, gave $200 for each in excellent condition. That included all the surrounds, etc. that snap in place along with the glove box door. The one I patched with JB is still fine, these are for project trucks with dashes wrecked beyond repair.
Old 11-28-2022, 04:20 PM   #21
Jeepwm69
Anyone have a tutorial on replacing a dash?
Just picked up a 95 with one tiny crack to replace Dad's pretty busted up dash.
The one I bought came complete with passenger side ducts, and metal supports underneath. Guessing this isn't going to be an easy job.........
Jeepwm69 is offline   Reply With Quote
Old 11-28-2022, 10:47 PM   #22
My suburban came with that crack shown in the original post. It was a sheriff's K-9 unit and when they remoo..., more like tore their equipment out they left carnage behind. I have a nice used surround but think I'll just glue the main dash. It's just a driver anyway. But when I press the crack together it's barely visible.
Good luck with your project. Sorry can't help on the tutorial
Old 12-01-2022, 08:49 AM   #23
Mr_Rich
Mr_Rich's Avatar
There is a two-part epoxy made especially for repairing plastic. I've had very good luck with repairing plastic parts. Saved me $$.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 12-01-2022, 08:58 PM   #24
Just call me Sean
Just call me Sean's Avatar
This stuff?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-02-2022, 02:11 PM   #25
Mr_Rich
Mr_Rich's Avatar
Originally Posted by Just call me Sean View Post
This stuff?
Yes. Give it a try. I was able to repair the plastic brackets that retain the rear bumper cover on my gf's Scion. Those brackets cost over $50 each. It's been over a year and still holding. What you might want to do is glue a piece of plastic on the back part of the crack and clamp it until the glue sets. You will have a strong repair.
1989 K1500 Chev. EC
