Tires for rally wheels?
Hey gang. I could use a little help selecting some tires. The truck is a 68 SWB with rear leafs. I will have 15x7 rallys up front and 15x8 rallys in the rear. I plan on starting with a 3-3.5/5 drop but, I can see it ending up being more like a 4-4.5/6 drop when all is said and done.
I was thinking 215/70/15 in the front and 275/60/15 in the rear. Only problem is.... the 215/70/15 BFG Radial T/A's are on a nation wide backorder with an unknown ETA. Will that combination even look right with that drop? What other sizes and/or brands of tires would you guys suggest for my situation? Thanks in advance.
'68 SWB Fleetside '98 K1500 Silverado |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Tires for rally wheels?
We are in the same boat brother. I have been looking to order the exact tires for my truck but the backorder thing is killing any hopes of that.
I know! Plus the $60 mail-in rebate on 4 BFG tires ends on the 25th. I may see if I can just buy them now and wait for them as long as they aren't discontinued permantly.
Moderator
![]() Join Date: May 2007
A 4/6 drop with 215 70 15's up front and 275 60 15's out back is perfect IMO. I am running that exact tire/rallye wheel combo on one of my trucks now. I have a 2.5 spindle drop up front and 4" drop out back. It looks good....but the 4/6 will look even better.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I run a 235/70 fr and a 255/70 out back and fills the wheelwells nice
I'm just glad to be here!
Here is another option for the front.
The 215/70-15 is 26.8" tall (I also PREFER this size, but since it is on back order....) These are all BFG Radial TA tires.... 225/70-15 is 27.3" tall (imo it "looks" better on a 7" rim than the 215/70)(also on back order) 215/65-15 is 26" tall (in stock at Tirerack.com)( this might be my choice for a 6.5" rally rim..) 235/60-15 is 26.1" tall (in stock at Tirerack.com) For the rear I would consider the 255/70-15. Other option another brand tire.... Firestone Indy 500 has the 215/70-15 and the 275/60-15 (or 255/70-15), and they show in stock at Tirerack.com...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 04-23-2010 at 02:07 PM. Reason: other brand... |
![]() Join Date: Sep 2007
Im glad I ran into this, I had no idea what size tire to run on my 15x7 steelies up front with a bagged suspension, stock control arms and 72 spindles
1967custom |
Thanks for the help and the suggestions guys.
#9 | |
How tall is the 255-70?
i did 275/60/15 rear and 215/60/15 seems like its gonna give me a nice rake im dropped 5/7 but no motor in it atm so cant really tells lol
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
#13 |
The 215/60 is pretty short. I have 235/60s on the front of my junk and they are too small. I'm going to buy a tire at least an inch taller than they are to get mine looking better. I think you might find the tire you have too small once you get the truck finished.
#14 | |
#15 |
Hey Scoti. What tires are you running on the Bronze Beater? It's got a nice stance. Sweet trucks you got there BTW.
#16 | |
255-70-15's on 15x8" truck ralleys
#17 |
so if ya got 4 15x8 ralleys, what's the best tire size to run for the look, with a 4/6 drop?
R.I.P. Killer 71 10/26/07 |
#18 |
Hmmm.... So that's 27.62" F & 29.1" R. That looks good.
#19 |
i run 245/60-15 front and 275/60-15 rear with a 4/6 drop and love it
1986 Chevy 2wd swb 1937 Ford sedan 2012 Silverado |
#20 |
6.0 powered square
I have 215/70s on a 7" rim 275/60s on a 8 Looks good to me
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#21 | |
any picts?
#22 |
For 15x8's all around, 255-60 & 275-60's. What about trading two 8's for some 7's?
#23 |
I think I'm just gonna wait for the 215/70 T/A's. I'm not in a huge rush to get the wheels and tires mounted. There are plenty of other things I can work on in the meantime and I don't want to compromise when it comes to this truck.
#24 |
15x8 rallys all the way around with a static drop Id say 255-70 15`s all 4. if its a longbed. 60 series if its a shortbed
1967custom |
#25 |
thanks guys...scotti, was you talkin to me?
