Old 04-27-2010, 08:49 PM   #1
jfweaver
49 chevy floor replacement
I have started to cut the floor out of my 49 chevy does anyone know how to put a complete floor pan in? Mainly I need help with how to take out the rockers and where to weld the pan to the cab. SHould I cut the rockers out the grind it down to how I need it or?
jfweaver is offline   Reply With Quote
Old 04-28-2010, 12:11 AM   #2
mylow53
mylow53's Avatar
Re: 49 chevy floor replacement
it ain't easy!!! make sure your all braced up before you remove any of the floor. once you remove your floor the cab will flex and then your can of worms is wide open.....
the best plan for a floor is a bunch of patience and lots of time... but no worries a lot of rookies have done this. post some picts and we might be able to help you decide what has to be replaced....
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 04-28-2010, 10:27 AM   #3
rollinrooster
rollinrooster's Avatar
I replaced the complete floor in my '49.I braced the cab everywhere and then removed it frome the frame and flipped it onto its back.With the cab on its back this seemed to make it alot easier to work on.As for the floor i used dynacorn they have a complete floor that has all the factory braces and fits back in like a glove.I included a picture of my truck at its current stage and can take more pictures of the floor if you would like.Hope this helps and good luck!
rollinrooster is offline   Reply With Quote
Old 04-29-2010, 09:22 AM   #4
918733
I would like to see some pics especialy if you have some of the install.
918733 is offline   Reply With Quote
Old 04-29-2010, 09:49 AM   #5
rollinrooster
some of the pictures of when we put the floor in are on an old cell phone i have.I have been trying to get them off of it but havent had much luck.I will tell you that all i did was cut the old floor out close to where it is spot welded in at and then i used an air hammer to finish getting the rest of the metel around the spot welds.Once all the old metal was out and everything was cleaned up the new floor went back in like factory.
Old 04-29-2010, 12:01 PM   #6
98turbls1
GT
Greg,
Did you just tack in some rebarb to stiffen everything up before you cut it out? I'm going to be replacing mine here shortly too so I am trying to formulate a game plan.
98turbls1 is offline   Reply With Quote
Old 04-29-2010, 06:11 PM   #7
mylow53
mylow53's Avatar
on my floor i only replaced kick panels and a section near the clutch most of my floor is original.. suprizing for an oregon truck! even then i did some braces just incase.
GT
Greg
Old 04-29-2010, 07:59 PM   #8
jfweaver
I can post any pics it wont let me. they are to big
