Old 01-21-2001, 11:43 PM   #1
philhyde
Question 6.5L Diesel?
What is the reliability of this engine for this year? I seem to remember hearing not to good things of the 6.5 this old.
Found and '82 GMC pretty cheap - need buying recommendation.
thanks,
Phil
philhyde is offline   Reply With Quote
Old 01-22-2001, 12:09 AM   #2
philhyde
Post
Sorry guys - I meant the 6.2L Diesel.
I've been reading about the injector pump problems online. Wonder if this should keep me from buying.
thanks,
Phil
Old 02-22-2001, 06:07 PM   #3
tibbarkcaj
Post
Early 6.2 diesel engines did have problems.
The injector pump i wouldn't worry about.
The 6.2 Had a problem with cracking on the # 4 and 5 main journal and causing oil pressure problems. But hey if it's cheap enough I would buy it and drive till something goes wrong. You can always put a small block in it. That's easy.
tibbarkcaj is offline   Reply With Quote
Old 02-23-2001, 09:24 PM   #4
DUNE GOON
Red face
I've owned one (82 6.2L) for the past 5 years and never had a problem. Until I changed my fuel filter. Oh man. But it's a beaut and it's still going.
Cameron Gunlock AKA Dune Goon
addicted2dunes@hotmail.com
http://communities.msn.com/PROSTREET59CHEVYAPACHE
DUNE GOON is offline   Reply With Quote
Old 02-26-2001, 02:45 AM   #5
Adam
Post
And remember, if it's a diesel from the factory, that means no emissions testing when you put a gas engine in it!
'93 1/2-ton Cheyenne 2wd
408" smallblock with vortec heads, 9.2:1 CR, Performer Intake, 454 TBI, Comp Cams XE268H cam, custom chip, Thorley headers/true dual exhaust. 4L60E w/ Trans-go kit.
Adam is offline   Reply With Quote
Old 02-26-2001, 11:02 PM   #6
philhyde
Post
Thanks for the advice, guys.
Since my post, I have bought a great 1982 GMC with 6.2L diesel, and found a great resource on the 'net:
www.62-65-dieselpage.com
Regards,
Phil
Old 03-08-2001, 08:02 PM   #7
Chevy409
Giddy up giddy up...
Chevy409's Avatar
Post
Ditch the diesel for a gas job. I would worry about the injector pump. There's a plastic gear in there that wheres out very quickly and plugs the return line to the engine, the truck slowly dies until you can't go over 15mph... time to fix. Also, in my opinion, the 6.5 sucks just as much. A few more cubes but still has the same problems as 6.2, don't know why they thought throwing a turbo charger on would solve anything. Don't get me wrong, the 6.2 is a torquey engine and fun while it lasts but that isn't going to be trouble free by any means.
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site...
Chevy409 is offline   Reply With Quote
