Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-07-2010, 02:23 PM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Dr. Holley needs helps with a Q-jet
Had a guy give me a bunch of carbs if I could just get his Q-jet to quit spewing gas out of the accel pump shaft. My immediate first thought was just to replace the pump arm assembly but then I started thinking that a bad diaphragm wouldn't cause that.
When the float level is set too high or there is a problem with the needle and seat not closing on these things, do they tend to shoot out the pump arm hole in the top? Seems that since fluid will always follow the path of least resistance, that would make sense. Thanks!
prostreetC-10 is offline   Reply With Quote
Old 05-07-2010, 04:53 PM   #2
cableguy0
Re: Dr. Holley needs helps with a Q-jet
Is it running bad otherwise? Is the carb flooding the engine? I think your on the right track with the float. I would pull the top off and make sure the float isnt sunk. I assume stock fuel pump etc? Is it leaking from anywhere else?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-07-2010, 11:58 PM   #3
prostreetC-10
My Carbon Footprint
What's funny about this "deal" is that I was handed the carb. Never seen it on a motor. Just what the guy said. He gave me 5 carbs and asked if I could fix the problem with the one in return. I even told him that I would have no way of testing it once done because I don't have a spread bore setup to test on. I think I'm just gunna "pop the top" and have a look see. Even if the diaphragm was bad, it should recirculate in the bowl and not have enough force to shoot out the hole for the pump assembly....I would think. I'll probably see a jacked up float or a turd in the N/S assembly when I pull it apart.
Thanks Mr. Cable
Old 05-08-2010, 03:31 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Probably the float or needle and seat .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-08-2010, 12:09 PM   #5
cableguy0
Nothing like jumping in head first with your eyes closed. Hopefully you can find the "smoking gun" its so hard to fix stuff without actually seeing what its doing wrong. Good luck, I'm gonna bet you find bad needle and seat or a float with a hole in it.I would double check and ask the guy what he was using for a fuel pump though. Make sure it wasnt an issue with too much pressure.
Old 05-08-2010, 06:59 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Been a while since i been in one , but i remember a ball bearing type check valve for the accelerator pump that is tempremental about seating some times . Maybe im way off though .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-09-2010, 04:07 PM   #7
joes50pu
Sounds like you have a bad float "heavy causing the float level to be too high". You also could have a bad needle and seat but you'll get that with a new rebuild kit. The check ball someone mentioned is below the accelerator pump and just keeps the gas from draining back into the gas chamber below the float. No check ball means no accelerator pump squirt.
joes50pu is offline   Reply With Quote
Old 05-10-2010, 12:03 AM   #8
prostreetC-10
My Carbon Footprint
I love these deals because I told him I would "look at it" and had no way of testing it when I was done. I'll see what I can do and that is that. It's about free to him because he was not into the carbs he gave me.
Funny side note: I build a little 600 for a guy over the weekend just for fun. He barely was able to make it to my house, his bronco was running so bad. I wasn't really happy with the throttle position to get the thing to idle. Up there a ways in the trans slot. Decided to throw my light on the balancer. This guy's inital was literally at TDC!! To top it off, the guy had his vac can on his brand new MSD plugged. Imagine driving around all day at TDC plus just a little mech advance. Just to be "safe" I put him at about 14* and hooked up the advance can. The guy about crapped at how good it ran. It's amazing how many really successful carb rebuilds I have by properly setting their timing!!! LOL
Old 05-10-2010, 02:14 AM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
My 49' is the same way , bone stock vortec with 600 edelbrock & hei . I took it in to get some warranty work done on the paint . I go to leave in the truck after the repair a week later and it won't hardly even run . Headers are about to melt . I go home grab my race track bag and come back . Timing set at 6 degrees after tdc and idle mixers all the way in and cracked off seat . Im like WTF ! Kid comes out of the back and says "do you like it ?" . Im like "like what ?" He says " i adjusted everything for you and now it sounds like it has a cam ". I tell the owner don't ever let them mess with my truck again . Headers are now blue .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-10-2010, 12:48 PM   #10
prostreetC-10
My Carbon Footprint
lol. I'd have said if I wanted it to sound like it had a cam I'd pull off a spark plug wire.
