Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-10-2010, 03:03 PM   #1
dougminton
dougminton's Avatar
Big Block ignition timing
I need some help with ignition timing. Its a 462 10 to 1 compression oval port heads with big valves .590 intake .610 exhaust camshaft single plane intake holley 780 MSD HEI. Current timing is 15 initial 36 total. Any help would be greatly appreciated.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 05-10-2010, 04:30 PM   #2
jgreene0717
Jason
jgreene0717's Avatar
Re: Big Block ignition timing
That should be in the ball park. Just listen out for any detonation while driving and if you are getting any now you may want to try it at 34 degrees total with vacuum advance disconnected.
jgreene0717 is offline   Reply With Quote
Old 05-10-2010, 10:43 PM   #3
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Both my big blocks seem to love about 18* initial and 36* total.
prostreetC-10 is offline   Reply With Quote
