Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-12-2010, 04:40 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Suspension-Which route?
Truck-1985
What I am looking at in the near future- BBC, 350 or 400 trans, 9" or 12 bolt axle.
I have thought about swapping to a trailing arm suspension out of the earlier trucks in the rear or rebuilding my rear springs and add some caltracs.
If I go with the caltracs, what else should I do in the rear?
What should I do for the front?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 05-12-2010, 05:24 PM   #2
70shortwide
Re: Suspension-Which route?
i would do mono leafs and caltracs in the rear they work awesome
70shortwide is offline   Reply With Quote
Old 05-12-2010, 05:45 PM   #3
ripdog28
ripdog28's Avatar
What will the truck be used for? Can get a 4link for under $400.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 05-12-2010, 10:32 PM   #4
softballnrd27
I will drive it on the street some but I really want to build it more for the strip.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 05-13-2010, 10:32 AM   #5
noonzor
if your going for the strip i'd go four link. set up right they are streetable, and will hook excellent at the track.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 05-13-2010, 10:55 AM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Dave Morgan said it in his book on doorslammer suspension....
misery loves a bunch of holes in a suspension bracket
I've got two 4link vehicles and let me tell you,,,,, IF your NOT willing to spend the time to sort it out,,, go ladderbar. MUCH easier and you might have some sanity left when you get it hooking and driving straight.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-13-2010, 02:25 PM   #7
shawnt
shawnt's Avatar
I also have an 85..
I'm going the caltrac/mono leaf route.
I've got a 496 in the works right now. Should be done about a month after i get home.. so mid-late july? August?! Somewhere in there.
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 05-14-2010, 10:06 AM   #8
Hertzdaddy
Has anyone moved their leafs under the frames (ala s-10) to gain tire clearance on a tubbed truck? I've seen this once and I just wondered if anyone else has tried this. I'm familiar with moving the leafs inboard but that narrows the suspension points right much and can cause instability.
Hertzdaddy is offline   Reply With Quote
