Old 05-24-2010, 06:54 AM   #1
13gman
13gman's Avatar
headlight swap
Hey guys, Hope you can help me. I want to put the one piece headlight from a 94-98 chevy truck on to my 90 Suburban. How hard is the swap? I've seen a couple of burbs like that.
13gman is offline   Reply With Quote
Old 05-24-2010, 09:28 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: headlight swap
Anyone try this before?
tvblazer78 is offline   Reply With Quote
Old 05-24-2010, 02:32 PM   #3
justpball
justpball's Avatar
Re: headlight swap
the only prob is the 90 style is a little more angled then the 80 style so the headlights shine on the other side meaning the driver side shines on the pass side and vise versa, i only could tell in the fog because you could see the beams...lol it is a lot of work too!
I think some guys used the early model 87-88 monte carlo or the caprice
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 05-24-2010, 10:47 PM   #4
BIG V
Re: headlight swap
ive seen people put the cavalier lights from the same era in them way back when these were new trucks. it was a one piece glass light with a high beam and a low beam side by side.
BIG V is offline   Reply With Quote
Old 05-25-2010, 06:15 PM   #5
13gman
13gman's Avatar
Re: headlight swap
I'm going to try some Caprice lights. Justpball is right, I dont want the lights to cross paths. I want the lights to be the same length as the parking lights so the cavilers lights might not work. Thanks guys for giving me suggestions.
Old 05-25-2010, 11:07 PM   #6
BIG V
Re: headlight swap
the 87 cavalier lights are the same size. i dont remember the lights crossing paths i can take a pic if you like.
Old 05-26-2010, 05:06 AM   #7
13gman
13gman's Avatar
Re: headlight swap
Yeah, Big V I would like to see some pics. As far as I said about lights crossing I meant the 94-98 chevy truck lights. Since those truck front in is not flat like the Suburban the lights are in a angle in the housing. If I install them flat on the Suburban the headlight beam would be facing in and would make them cross.
Old 05-26-2010, 10:57 AM   #8
justpball
justpball's Avatar
Re: headlight swap
I think some people used a celebrity headlight too
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-26-2010, 11:01 AM   #9
justpball
justpball's Avatar
Re: headlight swap
or monte carlo
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-26-2010, 08:52 PM   #10
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
Re: headlight swap
YES, 87 celebrity are definately the best choice for this. I buy every set i can when i go to pick a part. the lights are glass lens, so you dont have to worry about your HID's discoloring the lens for one. for two, they are almost exactly the same size as 2 4x6 headlights put together, i have a set in my 80 monte carlo header panel and they fit nice there too. they are the flattest ones i could find and they work well into damn near anything. everybody down here wants "bulb" lenses n their frontends. should look nice, ive seen the 90 caprice ones in a 90 clip before and they made it work, but i think they were too big, looked like they cut quite a bit from the grille to make them fit.
the other thng about the celeb lights is that when you take them out, they are in their own lil basket with all the adjustment bs staying intact, and i thnk its one bolt and two studs with a c-clip holding them on, very easy to adapt to something else, just drill three holes and mount em up. im going by my pops place in a bit n ill get plenty pics of my header panel for you guys since its still off the car.
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
Old 05-26-2010, 11:04 PM   #11
knightowl73
Re: headlight swap
here ya go, pics of 87 celebrty headlight n my 80 monte header panel
Old 06-06-2010, 11:20 PM   #12
Hotrodd 72
Re: headlight swap
heres a pic of my 83 with 91 grill
Hotrodd 72 is offline   Reply With Quote
Old 06-07-2010, 08:54 AM   #13
justpball
justpball's Avatar
Re: headlight swap
thanks knightowl
87 Crew SWB
Build for the crew
90 burb 2wd
Old 10-11-2010, 04:10 PM   #14
Fastest32
Fastest32's Avatar
Re: headlight swap
Has anyone done this with the celebrity lights? I found a set at the junkyard and I'd like to do it to mine.
Fastest32 is offline   Reply With Quote
Old 10-11-2010, 05:30 PM   #15
Hotrodd 72
Re: headlight swap
ya i put a 91 grill in my 83 and soon i will put the celebrity lights in place of the 4 light set up
Old 10-11-2010, 05:34 PM   #16
Fastest32
Fastest32's Avatar
Re: headlight swap
Awesome. Can you post some pics when you do? Nice suburban by the way.
Old 10-11-2010, 05:52 PM   #17
Hotrodd 72
Re: headlight swap
sure i got 5 kc's on top now i'll post a pic in a min
Old 10-11-2010, 06:05 PM   #18
Hotrodd 72
Re: headlight swap
here's the new KC's have 2 more the the brush guard but need to make brackets
