Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-28-2010, 06:46 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
MAF sensor modification
I'm working on a second modification to the intake system. First was ram air, now a MAF modification. I found a sensor on craigslist for $30. It included the TBI connection down to the upper filter box connection.
Removing the screen was easy. A small c-wire holds in place. The screen is not really thick. I'm not installing it without a screen. I've ordered some new screen material. The screen will be thicker and provide more airflow. Hopefully the material will arrive early next week.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-30-2010, 01:36 AM   #2
gchemist
gchemist's Avatar
Re: MAF sensor modification
The new screens arrived today. I used a set of scissors to cut both pieces.
#1 - stock screen = 1/4" thick
#2 - plastic 1/8" 6:1 ratio = 3/4" thick
#3 - aluminum 3/16" 5:1 ratio = 3/4" thick
Once I clean the sensor, I'll install the aluminum first. It has a better flow ratio due to honeycomb size. If engine codes appear then, I'll install the smaller plastic screen. The new screens have 1/2" more flow path. A smoother air flow over the MAF wires should provide better readings.
Here is a video demonstrating the affect of airflow.
Old 06-01-2010, 02:06 AM   #3
gchemist
gchemist's Avatar
I cleaned up the MAF. It was really dirty. Not even using some MAF cleaner removed all the gunk off the little resistors. I was careful to clean off the grim built up over the years. The sensor is ready to install.
The sensor uses a contact for operation. I cleaned off the grime with a wire brush. I also used the brush to remove oxidation and grime.
Old 07-24-2010, 08:00 PM   #4
gchemist
gchemist's Avatar
The experiment begins! I installed it today. I'll post pictures after I download from my camera.
