Old 06-08-2010, 07:33 PM   #1
Malibob
Malibob's Avatar
Z-ing a frame (REAR)
Can you z the rear of the frame? What I am thinking is right behind the cab before the bed mounts. Then right in front of the rear bed mounts. I can draw up a sketch but just wondering if it can be done and any ideas on how.
Steel plate and gussets is what I was thinking. Sketch coming tomorrow.
Alternatively, if I have to step notch instead, what do I do with my crossmember?
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 06-08-2010, 07:52 PM   #2
SCOTI
SCOTI's Avatar
Re: Z-ing a frame (REAR)
Yes, it can be done..... http://67-72chevytrucks.com/vboard/s...d.php?t=381425
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-08-2010, 09:36 PM   #3
Malibob
Malibob's Avatar
You sir are a bas ass! That is exactly what I was going for.
Flickr
Old 06-08-2010, 10:11 PM   #4
Malibob
Malibob's Avatar
Originally Posted by SCOTI View Post
Why did you relocate your axles? Correct me if I am wrong, but, if I move the entire sections that holds the bed mounts, crossmember, shock mounts and springs couldnt I keep the stock setup and still drop the hell out of the truck? The only geometry changing would be the axle. Right? The added c-notch is an awesome idea too, I like the combination.
Flickr
Old 06-08-2010, 11:45 PM   #5
SCOTI
SCOTI's Avatar
Because even @ a 6-8" drop, the axle C/L shifts forward due to the geometry of the truck-arms. I just compensated for that & the additional drop allows for more travel/drop. I like the wheels centered or slightly to the rear on these trucks so I set it up w/some room for adjustment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
notch, z-ing
