Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-22-2010, 09:41 PM   #1
292farmer
292farmer's Avatar
where do i splice in?
ok so i bought a aftermarket washer pump, directions are crap, so i looked around the forum and it seems the hot wire goes to the yellow wire and the negative to the middle blue wire. in the first pic is the wires that plug into the back of the switch, is that middle wire the blue wire people refer too? and the second pic is of the old pump and wiper motor, which yellow wire do i splice into? the top nearest pump, is my thought(pic is sideways i used phone stuffed through radio hole) thank you
292farmer is offline   Reply With Quote
Old 06-23-2010, 12:15 PM   #2
raycow
Re: where do i splice in?
Why not unplug the wires from the stock pump, put spade terminals on the wires for the new pump, and plug those into the connector? This way you don't cut anything, and if you ever want to replace the stock pump you can do it.
Ray
raycow is offline   Reply With Quote
Old 06-23-2010, 01:12 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
I did this to mine. Yellow wire going to the motor goes to the red wire on the external pump. Check with a multimeter that the yellow wire is hot with the key in the run position. Actually any 12 volt key on source will work. Black wire on the external pump goes to the middle blue wire at the wiper switch. I used spade connectors and was able to stick them into where they needed to go.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-23-2010, 10:18 PM   #4
292farmer
292farmer's Avatar
thanks guys just wanted to make sure before i made a mess lol.
Old 07-28-2014, 05:35 PM   #5
JonnyC10
I just did this on mine and the pump still isn't pumping. I know the pump works. I hooked pump + to yellow and pump - to the light blue middle wire on switch. Nothing.
JonnyC10 is offline   Reply With Quote
