Newer truck feul problems
I know you guys deal with older Chev trucks. I'm good with them myself. New stuff drives me crazy!
Re: Newer truck feul problems
Clogeed inline fuel filter maybe???
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
![]() Join Date: Jan 2003
Make sure you hear the fuel pump priming when you turn the key to run but it sounds like a ignition module issue. It is located under the rotor in the distributor. The module has a start and a run mode and in the start mode, it is looking for th e starting rpms (under 400). Once it sees the low rpm cranking, it gives a reference pulse to the ECM to fire the injectors. Once the injectors start firing and the rpms climb, it goes into the running mode and starts to control the injector firing rate. When you prime it, it spins up enough to get into the running mode. You can have the module tested at the parts stores for free, just make sure they test it a bunch (I usually shoot for a dozen times in a row). The module heats up as its operating and can pass when cool and fail when hot. When you remove or replace the module, you have to make sure that the white heat sinc compound/grease is in between the module and the dist base or it will fail. The heat generated in the module is disappated through the distributor body, no heat sinc compound, module will overheat. Make sure its heat sinc compound (should be white) not dielectric grease.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
Thanks a bunch!!!! What happened to gas and spark and it runs?
Tags |
fuel |
