Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-02-2010, 11:48 AM   #1
dbmx66
more updates. roll bar, alum driveshaft, nitrous kit... etc
well... i got more done these past couple weeks. got the 8pt roll bar from s and w, there like a 25 minute drive away, which is very convenient. i got my aluminum drive shaft made, finally, its only 3-1/2 but the guy who made it said itll with stand up to 1000hp,
with the roll bar i decided to strip the interior, like the carpet and what not.
the blue seats i had in last time i traded to my buddy for his nitrous kit, that was what the thread i posted about the nitrous for him, he decided he didnt
wanna mess with it.
my purging system is coming in the mail tonight, along with the safety blow down tube and valve and stuff
i undercoated the floor, finished running all my brake lines as well as the line lock, and finally got inside and outside of rims drilled and put the rims screws in
here are some pictures taken last week.
dbmx66 is offline   Reply With Quote
Old 08-02-2010, 11:51 AM   #2
dbmx66
Re: more updates. roll bar, alum driveshaft, nitrous kit... etc
here are some more
Old 08-02-2010, 12:04 PM   #3
noonzor
lookin clean man, very nice work. whats the specs on the motor?
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 08-02-2010, 01:17 PM   #4
CoggedBelt75
CoggedBelt75's Avatar
Your coming along quite nicely with your project. Have you taken her out for a spin yet?
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 08-02-2010, 07:14 PM   #5
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Truck is looking good man
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 08-02-2010, 08:38 PM   #6
djracer
djracer's Avatar
lookin good.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-02-2010, 11:09 PM   #7
dbmx66
thanks guys. no i havent driven it yet. ive owned it for 2.5 years now, bought it with a blown motor.
Old 08-02-2010, 11:11 PM   #8
shortbed70
shortbed70's Avatar
NIce so when we going to see some smoke and hear some noise?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-02-2010, 11:12 PM   #9
dbmx66
motor is a 355, eagle crank and rods, comp roller cam with harland sharp rockers and girdles, keith black pistons, 11.5:1 compression, cam is .575/.575, double roller timing chain, heads are cnc ported along with the intake which is an edelbrock victor jr., holley 750 carb
Old 08-04-2010, 09:29 AM   #10
custom70
custom70's Avatar
That fuel setup being beside the driveshaft looks a little dangerous to me. If the joint breaks and takes out your filter/line and sprays gas every where not going to be good.
custom70 is offline   Reply With Quote
Old 08-04-2010, 12:24 PM   #11
dbmx66
im putting a drive shaft loop on the cross member, so i think ill be fine. hopfully lol
but the u-joints are 1350s which are beasts compared to the 1310 stock ones.
Old 08-04-2010, 03:58 PM   #12
grinch4om
dang its hot
grinch4om's Avatar
custom 70 is right...please contemplate putting the tank behind the axle...better for weight distribution as well as safety...
grinch4om is offline   Reply With Quote
Old 08-04-2010, 04:00 PM   #13
Super73
Super73's Avatar
The other thing I notice was the regulator on the firewall. Not sure tech will let that fly.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-04-2010, 07:28 PM   #14
dbmx66
i dont have room anywhere else to put it
Old 08-04-2010, 08:26 PM   #15
Super73
Super73's Avatar
Unfortunately the tech guy/girl won't care.. I have heard that you can bend a U shaped piece of metal mount that to the fire wall then mount the regulator to that. I can't promise that will pass, but that's the rumor I have heard. Just trying to save you some grief.
Old 08-04-2010, 08:52 PM   #16
dbmx66
thanks for letting me know tho sir.
Old 08-04-2010, 10:17 PM   #17
team39763
Are you running the stock front brake system?
Is your rollbar tied into the frame beneath the cab?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 08-04-2010, 11:14 PM   #18
dbmx66
its the stock setup, but new rotors, calipers, lines and prop. valve. and with a linelock
no, instead of cuting through the floor we welded 6x6 inch plates to the floor then the bars to the plate. s and w race cars sed that was legal to do.
Old 08-05-2010, 04:05 AM   #19
Super73
Super73's Avatar
I believe you need out riggers from the frame to the bottom of those 6x6's.. In a frame vehicle the cage has to tie in to the frame. It sucks because our frames are so narrow.
Old 08-05-2010, 01:16 PM   #20
dbmx66
yea, thats wat i told the guy at s and w and he sed the plates are fine.
Old 08-05-2010, 01:38 PM   #21
team39763
Shouldn't it still pass inspection for test'n'tune?
Old 08-05-2010, 02:36 PM   #22
dbmx66
i hope so.
Old 08-05-2010, 09:37 PM   #23
Marv D
Registered Truck Offender
Marv D's Avatar
It will pass till he makes a full pass and runs under 11.49, and then he's toast. Like Super said, no matter what S&W told / sold you, the roll bar / cage MUST be tied to the stock frame,, no if's, and's, or butt's
Gen Reg 4:10
ALL CARS WITH FULL FRAME MUST HAVE ROLL BAR ATTACHED TO FRAME
As suggested, build outriggers (od same diameter as main hoop) that come from the frame, up to sandwich the cab floor between a upper and lower 6x6 pad and you'll pass.
However I do want to say,,, BEAUTIFULL build so far. And as far as tech items,, all you can do is hope, and modify/fix if they deny your tech card. If your planning on spending much time at the track, PLEASE get yourself a rule book and check things out throughout your build. Every rule in there was created because someone got hurt doing it otherwise. May not be you, may be a spectator or the guy in the other lane next to you. It's a frustrating and expensive journey, but the worth doing right.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-05-2010, 11:26 PM   #24
dbmx66
thank you. and yes im changing my belt setup, going with no power steering with an electric pump. so ill be machining a bracket that will mount the regulator to the head. and yes that makes sense, i will weld on frame out riggers. ill be getting a rule book asap. and thanks for the compliment, its been fun so far, i just want to drive it so badly, but hey, all good things take time.
