Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-05-2010, 08:24 PM   #1
W.M.Coleman
Graduation Present, One Bad Mudder
Hey fellas, I got a 65 Longbed with a 327 4 speed. I got it from my bro for my graduation present. Its pretty unique, 2wd with a lift . Anyways, aside from the previous owners shotty craftsmenship I think I've got alot to work with.
I'm wanting to put mid 70s-80s axles under it with 4:11 gears, probably a little bit lower, Married transfer case. 6 inch lift or higher, and run with 38s.
Engine wise, I'm planning on building a 377, with hopefully 425hp at 5 grand or so. Really haven't thought this part out yet, I'll probably throw in this 305 I got here at the shop as a mule motor.
Any of you guys got any gearing ratios yall think are good, axles to look out for?
I'm more of a hot rodder than a mudder. Well, I haven't went mudding in any chevys yet, I drive my buddies 78' Bronco on 36s, while he drives his Samurai on 38s
W.M.Coleman is offline   Reply With Quote
Old 08-05-2010, 10:04 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Graduation Present, One Bad Mudder
I'd rebuild the 327. I'd suggest a 205 tcase, dana 44 front, 14 bolt rear. Talk to Kurt at DIY4X to help with the front axle setup. For gears it all depend on your transmission. Looks like a good foundation for a build. Good Luck
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 08-06-2010, 11:14 AM   #3
W.M.Coleman
Thanks man, what are you runnin on your truck
