Old 08-09-2010, 12:29 PM   #1
Dads69C10
Dads69C10's Avatar
73 Front drive shaft question
I need help.. My 73 blazer is missing the front drive shaft and i found a guy nearby with a ton of parts. I asked him if he had a front drive shaft for a 73 K5 he said yes and asked me the following..
sure do. I need some specs from you though. Is it the type that has a flat flange on the t-case and uses 3/8" bolts to mount, or the type that uses 5/16" NF threads to mount?
now he may as well be speaking chinese to me, so can somebody help me out. thanks
J
1969 C10 stepside
1973 Cheyenne Blazer
Dads69C10 is offline   Reply With Quote
Old 08-09-2010, 06:24 PM   #2
russgt
russgt's Avatar
Re: 73 Front drive shaft question
I am not 100 percent sure, but I think this relates. check out the front driveshaft assembly. My 76 has #1. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=153
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
