08-12-2010, 12:12 AM | #1 |
1969 1/2 ton suspension in a 1965 3/4 ton...
I'd like to put a 1969 1/2 ton suspension in a '65 3/4 ton. I've wanted to change to a 1/2 ton for a while. Do you seen any reason why I couldn't take the complete front suspension including the cross member from the '69 1/2 ton and put it in the '65 3/4 ton? Same question does for the differential and tracking bar.
08-12-2010, 12:24 PM | #2 |
Happy to be here
Re: 1969 1/2 ton suspension in a 1965 3/4 ton...
You can do that, but I would find a 73-87 donor. The replacement parts are much cheaper
08-12-2010, 03:19 PM | #3 |
The 69 stuff will swap. The Panhard bar frame bracket might need to be swapped as well (or get an adjustable Panhard bar from ECE or CPP).
