Master & Booster Angle
Local hot rod shop seems to think there is an issue with the angle of my master cylinder. It is lower in the front. I realize this is a Corvette style master. I am doing a 4 wheel disk conversion. The stock master was at the same angle. The booster and bracket are stock. This is a factory power brake 72 1/2 ton LWB Cheyenne Super. Does it look like this booster and bracket are installed correctly?
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 08-13-2010 at 04:02 PM. |
Re: Master & Booster Angle
it's normal ... the local hot rod shop has a lot to learn ...
I had never considered that it was wrong but when it was mentioned I thought I better research it a little further. No need to name the shop. They are reputable. They have been around for a long time and put out some very high quality work.
Don't take this wrong. I agree with you Shane but If I could hear it from a few other members or better yet see a few pics of other stock boosters it would make me feel better.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 08-13-2010 at 04:07 PM. |
No offense taken and I would do the same.
Grandpa in the rustmobile...
If you need a pic I can post one LATE tonite or later in the weekend...it looks about right, maybe a tad bent but looks ok to me
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
![]() Join Date: Apr 2010
Here is mine on my 69. It tilts forward the same as yours.
ROD ![]() 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
Thats cause you bought it from CPP instead of us
![]() its normal |
I asked the same thing when i reinstalled my part. They were not tight but leaned forward even less after i tightened everything up. My opinion says it is okay.
http://67-72chevytrucks.com/vboard/s....php?p=3900740 |
I just went out and checked the 72 burb and it looks about the same as yours.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
From the top of my head, one of the first thing i noticed on my 68 was the angle , yes its normal .
Normal, it looks even more severe with a bendix master cylinder
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
I'm using a corvette MC it sets the same angle for almost 2 yrs. Leave it be.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#13 |
Thanks guys. I am convinced.
#14 | ||
"I ain't nobody, dork."
Yep... completely normal.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#15 |
![]() Join Date: Feb 2003
i just put a 7 inch dual diaphram booster on my 67 and it is tilted slightly but maybe not as much as yours. i would think that it is ok. i did mount the proportioning valve on a bracket on the firewall.
#16 |
Still plays with trucks
They tilted all the power brake master cylinders in that time frame. The cars have a severe rearward angle to them.
Don't know why they did it but it is normal with power brakes.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#17 |
I was planning to convert my 67 to power brakes. I was going to use a gbody booster and cylinder but realized the reservoir was designed to sit level when the firewall was at an angle in the "upwards" tilt which is opposite to what's posted above. Then I look at this thread from hit rod and I am really confused..
https://www.hotrod.com/articles/old-...-upward-angle/ |
#18 |
Who Changed This?
![]() Join Date: Jan 2013
My original drum/drum setup had the master pretty much dead level. You're looking at a car setup with the thing angled that high to clear the engine. my aftermarket disc brake upgrade has the master pointing down at a slight angle, not level like original. Just look at the different setups in this thread, and I think you'll realize that you have nothing to worry about.
#19 |
The stock location of the power brake booster and m/c always bothered me. I'm going to try a Capt. Fab. bracket and see if it will clear my shift linkage under the hood. This will make the m/c level and closer to the firewall and a lot more out of the way. Should be mocked up by the weekend and i can give a better answer.
#20 |
Active Member
![]() Join Date: Apr 2019
I'm running a wilwood setup (master, Prop Valve, spindles, brakes, rotors, etc...) and it's pretty tilted.
So much so, I'm seeing coating damage to the master from front edge brake fluid spillage. (not to mention the rear compartment isn't as full as I think it should be in this configuration) I've been thinking about putting some washers at the firewall studs to level it out some, honestly. |
#21 |
I had enough time to mount the booster m/c this will give you a general look at it. The factory mounting and linkage bracket points the m/c down on power brakes. Like Steeveedee said the non power m/c set level thats what mine came with. The 11" booster might have a clearance issue with the column shift linkage. Maybe that's what the factory came up with for the clearance issue? The set up you have under the o/p hood looks right.
#22 |
I had the stock set up on my truck. My problem was I couldn't get the valve cover off with the 11 inch booster. It was about a 1/4 of an inch away. I have roller rockers and some times need to get to them with out taking the brake booster apart. I installed the 7 inch double diaphragm booster and a Capt. Fab bracket. Works fantastic.
#23 |
![]() Join Date: Jun 2019
I have the same Wilwood setup as bigtop. I got it from classic heartbeat. It sits at the same slight downward angle.
