08-27-2010, 10:26 PM | #1 |
Got a new Suburban today
I saw a Suburban for sale local and went and looked at it. Not sure what I am going to do with it now that I have bought it, I will probably just sell it to someone that would like an original Suburban. I guess I could have Kevin make it a crew cab, he loves to cut in good metal. It is a pretty loaded Suburban, front and rear air, tilt, tach, 350 with a 350 trans. The same guy has owned it since 1987. What do you guys think it would be a good price to ask for it?
08-27-2010, 10:29 PM | #2 |
Re: Got a new Suburban today
It really looks better in the pictures than it does in real life. There is a spot of cancer that someone tried to fix behind the right rear wheel and the liftgate has some cancer and of course under the battery box has some too. The PO has recently installed new drums and brakes on the rear end, new battery, new master cylinder. It runs really good and drives down the road great. It still has the California smog on it and the smog pump is not frozen but the belt was removed at one time. I know from the Po that he rerouted the heater hoses because he thought that the heater core was leaking and the air conditioning was working last year but now blows hot. It also has an older Edelbrock carb on it. I think all the options on the SPID are still on the truck right now.
08-27-2010, 10:33 PM | #3 |
6>8 Plugless........
Nice score! I'm not sure what it is worth. But in our area people would ask atleast 5k just because of the options and clean body I'm guessing.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-27-2010, 10:38 PM | #4 |
TILT COLUMN GURU
Very nice.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
08-28-2010, 11:36 AM | #5 |
NICE
08-28-2010, 12:38 PM | #6 |
VA72C10
Not sure on value either but I do think it would go up exponentially if you took off the running boards Very cool original burb!
Looking for a 67-72 swb or blazer project in or around VA. |
08-28-2010, 12:48 PM | #7 |
Sweet burb! I'll take it off your hands for $1500...........
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-28-2010, 07:29 PM | #8 |
08-28-2010, 07:51 PM | #9 |
Is it a 71 or 72 3/4 ton? Does the rear air work...?
I would probably try to get it for around seven depending on what works, rust ...the usual and also if it was going to be a keeper versus reselling... Looks great!!! Nice Find!!! |
08-28-2010, 07:55 PM | #10 |
I won't be keeping it too long, found something else that I like better at the Good guys show in Pleasnaton today and my wife says my toy box is way too full, I only have about 12 cars and trucks, mostly trucks. The Suburban is a 72 3/4 ton and the rear air comes on but hot air just like the front air does.
08-28-2010, 08:24 PM | #11 |
No keeping secrets. Whadya find?
08-28-2010, 08:45 PM | #12 |
I was looking at a 54 4 door wagon, really cool
Here are some pictures of the bad areas on the Suburban. There was some rust that was kinda covered up by the right rear quarter behind the tire, some rust in the liftgate as seen in the pictures, some damage on the drivers door from the mirror, and a dent in the left front fender. There is also some rust under the battery box, go figure. Last edited by extd56; 08-31-2010 at 06:43 PM. |
08-28-2010, 08:49 PM | #13 |
Here are the pictures of the seats, the rear seatbelts do not match the rest of the belts. The other pictures I guess were when they used to haul a canoe on the top of the Suburban.
08-28-2010, 08:52 PM | #14 |
The drivers side front door panel is broken but I do have a complete white set on Ebay right now, I guess I should pull them. The rockers look to be in good condition. Also the steering wheel is junk, big crack in it.
08-31-2010, 06:42 PM | #15 |
This is the 54 handyman that I bought yeasterday, has been sitting for a long time. Now I get to play with it.
08-31-2010, 07:06 PM | #16 |
VA72C10
very cool! Love it! I am a big fan of big trucks and wagons!!! You've got them covered now
08-31-2010, 07:44 PM | #17 | |
08-31-2010, 08:33 PM | #18 |
It is a 150 Handyman but someone has put a 327 engine in it with a 350 trans and a 10 bolt rear end. It has also been converted to 12 volt with an alternator. I am still checking it out. love new toys and good surprises.
08-31-2010, 08:51 PM | #19 |
Another very cool score! Congrats!
09-01-2010, 11:29 PM | #20 | |
I had a V-8
Nice score!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
09-01-2010, 11:44 PM | #21 |
09-04-2010, 09:28 PM | #22 |
PROJECT 7DEUCE
Loving that wagon those are soooo cool... The sub is daily driver looking but damn I hate ochra...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
