Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-30-2010, 12:26 PM   #1
1FAST68
headers tested.
I just had my headers dynoed with a lower hp and lower rpm motor than mine.
Same cubic in engine though.
They lost 30+ hp and 40+ torque. Just wondering what I should see at the track with some new headers. That should be a seat of the pants difference right?
68 chevy truck
ls3, 418ci, pump gas 10.81@121.8 all motor. 1.47 60ft
70 suburban
350 tbi swap, 700r4, work in progress
1FAST68 is offline   Reply With Quote
Old 08-30-2010, 12:44 PM   #2
Super73
Super73's Avatar
Re: headers tested.
What were the two sets of headers?
I'm thinking about doing something different on my truck for headers too since the 418 will be going in real soon (maybe next Sunday). I thought about getting a set of 2" big block headers and modifying them slightly to go over the frame rail and exit where the wheel well used to be.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-30-2010, 02:17 PM   #3
1FAST68
Re: headers tested.
The set I have now is doug thorley tri y's. They are 1 5/8 into a 2" then 3" collector.
I am having some made that are 1 7/8 stepped to 2" long tube headers.
68 chevy truck
70 suburban
Old 08-30-2010, 03:06 PM   #4
Super73
Super73's Avatar
Re: headers tested.
I was thinking about doing something similar to a 1 7/8 stepped to 2" I might even go a touch bigger given the amount af N20 I plan on putting through it.
Old 08-31-2010, 12:45 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: headers tested.
You would likely benefit from a 2" primary with those cubes and the gun(s) you're gonna hit it with.
1FAST68: I'm not surprised a 1 5/8" primary choked down that 418ci, IMO a 1.875 primary is as small as I'd go on a n/a motor like yours.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 08-31-2010, 10:00 PM   #6
Wild83C10
Wild83C10's Avatar
Re: headers tested.
I bet the curved looked a lot different though. Peak numbers aren't everything. How did the area under the curve look?
1-5/8 primaries are too small for a 418.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-01-2010, 12:23 PM   #7
Super73
Super73's Avatar
Re: headers tested.
It is when your TQ converter flashes to your peak TQ
Old 09-01-2010, 04:30 PM   #8
1FAST68
Re: headers tested.
actually it was down everywhere, I am not worried about below my convertor stall.
68 chevy truck
70 suburban
