Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 09-10-2010, 06:49 AM   #1
Wvgearhead
Which rearend fits a 46
A body of mine picked up a nice 46 project. He is wanting to swap out the original diff for something a little better. Does anyone have a good donor list and the width. I think a gbody montecarlo should be close, but thought I would ask somebody that has already done it.
Wvgearhead is offline   Reply With Quote
Old 09-10-2010, 02:56 PM   #2
raycow
Re: Which rearend fits a 46
If you still have the stock rear, measure it over the drums and you should get something around 60". This means a G-body will be somewhat too narrow, but it should work ok if you are wanting the deep wheel look. For a closer match to stock, look at 68-74 Nova, 1st gen Camaro, or 4WD S-10. Early Chevelle will work too, if you don't mind dealing with the suspension brackets and lugs. I have used 55-57 passenger car rears in these trucks, but those are getting rather scarce/pricey now.
On a related issue, the stock front track is about 2-1/2" narrower than the rear, so keep this in mind if you are going to an IFS and you want the F&R track to match.
Ray
raycow is offline   Reply With Quote
Old 09-11-2010, 12:52 PM   #3
Wvgearhead
Thanks raycow,
I read somewhere that the 46 and down was narrower than the AD trucks. I have a 53 and it was suppose to be 58-60. The older was said to be 56-58, but I like to here a couple different opinions.
Old 09-11-2010, 04:44 PM   #4
raycow
Your figures are probably in the ballpark for track. The AD rear is about 62" over the drums. Track is less because of the offset built into the stock wheels.
I installed a 52 passenger car powerglide rear in a 46 truck and it was almost identical to stock width. That's where I got the 60" drum to drum dimension.
Ray
Old 09-11-2010, 08:32 PM   #5
Wvgearhead
You are right. My buddy measured the stock rearend today. Drum-drum 60.5 . I went with a 8.8 out of a ford explored for my 53
Old 09-12-2010, 10:45 AM   #6
raycow
Would you happen to know the width of the explorer rear? I'm not much good on Ford parts.
Ray
Old 09-12-2010, 12:33 PM   #7
Wvgearhead
I'm going out to work on the truck here in a few. I ll measure it and post it up.
Old 09-12-2010, 08:23 PM   #8
Wvgearhead
95 or 96 explorer with disk brakes 31 spline 8.8 measures 59.5
Old 09-13-2010, 04:31 AM   #9
raycow
Thank you for checking. That info could come in useful.
Ray
Old 09-13-2010, 02:45 PM   #10
Muleman100
Muleman100's Avatar
My '41 has a 1982 S-10 rearend, fits well, now I have 5 lugs on back and 6 on the front. That will change when I put a disc brake kit on the front with a 5 lug pattern.
" I never think of the future. It comes soon enough " - Albert Einstein
Muleman100 is offline   Reply With Quote
Old 09-13-2010, 04:59 PM   #11
Wvgearhead
Ok. Thanks
Old 09-13-2010, 10:14 PM   #12
Warrens69GMC
Warrens69GMC's Avatar
A 7.5 out of a 82-92 Camaro/Firebird is 60.5 inches.
Old 09-15-2010, 09:21 PM   #13
HarleyT
when I had my 46 I put a rear end in out of a 76 ish suburban. the axle pads where in the right spot anddidn't require anything. I rolled out the original one and rolled in the new one. Mine was also a 12 bolt truck posi with 373's.
Harley
HarleyT is offline   Reply With Quote
