Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-12-2010, 03:50 PM   #1
niceguy678us
1972 Highlander 6.0/4L80E/LoMax
I would like to start off by saying thank you to the people of this site that put the information out there for everyone to use freely. Everything I needed I was able to find by using the search function on this website as well as LS1TECH.COM, and LT1SWAP.COM.
I would like to thank my friend Louis who owns Ashfords Automotive. He and I worked together for years in the automotive mechanic industry, and he helped me with finding all the plug pin-outs on his All-Data service that I needed so I could do my own wiring. The pin-out information is also available on LS1TECH.COM, and LT1SWAP.COM.
I would also like to thank my machinist friend B.J. with Dubois Sheet Metal Works. I have been going to him for YEARS with my project ideas, and he has always been helpful and informative with my part designs and producing them with me. Your the man B.J.!!
I ordered my pull-out from http://jjsautomotiveracing.com/index.aspx . I dealt with Brian and he was ALWAYS helpful and informative with whatever I needed and gave me a HELL of a price. In my package I requested every hose be intact and attatched to the motor/trans. I also requested all the wiring be un-cut. Here is a list of everything I received from Brian:
2005 6.0/4l80e 65,000 miles
trans fluid lines
trans to transfer case adapter
oil cooler lines
AC lines
power steering lines
fuel lines
fuel pump assembly
radiator hoses
radiator overflow reservoir
radiator end tanks
intake tubing
engine bay wiring
engine bay relay/fuse box
ECU
under dash wiring
BCM
drive by wire (DBW) pedal
TAC module
gauge cluster
Here it is the day I brought it home
Out with the old 350 (never liked the gold Moroso bling anyway)
My friend Billy
Next I wanted to keep the body stock and not cut any extra holes. And I wanted to use the stock transfer case but I didn't like any of the adaptors/options that were out there. The advanced adaptor is too long and expensive. My np205 leaked from every seam and needed a rebuild anyway, so I looked at the Lo Max np205 upgrade kit. It came with a new case that has all of the different bolt patterns in the front face (like the 4l80e adapter pattern) rebuild kit with new bearings and gaskets/seals new 3:1 gears etc. I have to say that this guy knows his stuff, and he sells nothing but top shelf parts GUARANTEED! I had the pleasure of meeting the owner of JB conversions John in person and here's his site http://www.jbconversions.com/ . VERY intelligent man and he's also a huge off road enthusiast.
I wanted to keep the stock shifter and have it come through the floor in the stock location, so I designed a bracket that would bolt up next to the 2005 aluminum transfer case adapter piece.
Then the motor was ready to slide in for the first time.
I bolted the np205 up in the stock location and assembled the crossmember. Then I got to work on making the motor mounts. I already knew the stock front 72 crossmember wouldn't work, and I knew the LS engine blocks were designed to be a structural part of the chasis they were installed in anyway, so I made my mounts to suit. I can fab up a tubular crossmember later if necessary.
Frame brackets I made
Motor plates I made
Painting everything
Once the motor was in place I discovered that the 4l80 shifter stud was in EXACTLY the same place as the th350 that was there previously, so I just had to bolt up the linkages and VOILA!! Sorry I didn't get any pics of this I was tired that night and didn't think of it again, untill now.
I am going to ust the truck compressor with the vintage air kit, so I hade to make it work. I didn't want to spend a grand or two on a new serpentine setup when all I had to do was notch the frame and re-inforce it. I used a piece of scrap HEAVY wall 3 inch pipe.
Next I got to work on the gauge cluster. I wanted to use the 2005 cluster for a number of reasons, correct mileage for my motor, all the gauges I need are in one package, etc. I never worked with fiberglass before and thought this would be a good time to learn. So I used the old scratched up original 72 cluster panel for my first attempt. Later on down the road when I restore the truck, I will make another one with a new "pretty" panel. It actually came out o.k. and I know what to do, and what not to do for the next one so it will be perfect.
New acrylic face
Ready for glassing
I used felt fabrick from the fabrick store for the "walls"
Then soak the felt with resin
Now you can see the extra that needs to be trimmed/sanded flush with the 72 panel.
Then I used fiberglass cloth and resin to fill what was left of the old gauge holes.
A little bit of bondo/sanding
I used Rust-oleum "Multicolor Textured" (223525 Aged Iron) to get the texture back and top coated with Rust-oleum "Flat Protective Enamel" (7776 flat black). Both are available at any Lowes store.
Next hurdle was the gas tank. I had JUST put in a new replacement metal tank in the blazer and had the old tank's filler neck soldered/brazed (however they do it) to the new tank. I also wanted to integrate the 2005 fuel pump assembly into it for several reasons, fuel gauge to work, correct fuel pressure, etc. My first attempt came out great. I made a mounting ring that had welded nuts on the back side for the fuel pump to slide down into. I then had a machinist buddy of mine machine a little ridge for the O-ring to sit in, and he cleaned up the center hole so the pump assembly would "just" clear it and slide down into it.
Then I made a top ring that would sit on the top of the pump assembly. The bolts (with sealing tape applied) would slide through this piece and squeeze down on the rubber o-ring sealing everything up.
But I found out when I installed it that it hit the floor. Just about 3/4 inch too tall. So I had to go back to the drawing board. Lucky for me the fuel pump assembly's metal rods let it "collapse". So all I had to do was drop the mounting level down an inch or so to have PLENTY of room.
The springing action
Everything bolted tegether
From there I ran my one fuel line to the engine. I capped everything else off except for the vent lines and mounted her up.
Then came the radiator saga. My original plans were to find a radiator company that would make me an aluminum center section that was shorter than the 2005 so I could mount the end caps to it and install it in the 72 blazer core support. Since I had ALL the oil lines and trans lines, this would have been an affordable and EASY way to do this part of the drive line swap. BUT NOOOO, I got laughed out of radiator shops, hung up on, told me I was crazy "your putting a what in a what?" I left messages that never got returned, I got the run around, you name it. Everyone now operates on the "I can't find a part number in my catalog so that means it doesn't exist" philosophy. So I was on my own again..... Plan ""B"
I ended up buying an ebay replacement aluminum radiator.
And I decided instead of buying an expensive quality aftermarket fan, I wanted to use the camaro LS1 dual fans. They can be had ANYWHERE for 100 bucks, and there are affordable replacement motors available to service the assembly, so it's a win-win really.
The bracket I made out of aluminum that allows the camaro fans to slide in and lock just like the stock on the camaro radiator.
Then I made a wiring harness that mimicks the factory camaro wiring all the way to the truck ECU.
Remember that I got the 05 upper and lower radiator hoses with my pull-out and the original plan was to use the stock 05 radiator end caps so everything would be easy? Well since I had to ust the 72 replacement radiator, the 05 hoses wouldn't fit. So I went to my local O'reilly's and spent some time looking at all the hoses hanging on the wall in the back. I have been using that particular store for so many years, they all know me by name and didn't mind me hanging out back there for a while. So I found a few that might just work and they let me bring them home for test fitting. Well I found the perfect two hoses. The upper hose fits like it was made for me, and the lower hose just needed a little trimming.
The two part numbers
With the radiator section done I moved on the the coolers. I bought two B&M supercoolers to mount in front of the radiator, barbed fittings for the trans side and -10 AN for the oil side. I also purchased the Mocal LS series oil thermostat block with -10 AN male ends. Here is the link to the websites catalog http://97.74.103.94/files/newprod.pdf . I am also going to use the vintage air kit so the two coolers had to be recessed flush with the front of the core support for the vintage air parts to clear. In order to mount them flush I had to do two things. I had to move the lower radiator brackets foreward a little bit, space them up with a pieces of scrap 3/8ths plate and tack them down. Then I had to make two holes for the lines to go through and re-inforce them.
I used some HEAVY wall 3" box tubing scraps I picked up from my machinist friends shop.
Routing/making the lines
I hated cutting the core support but it was one of those things that just had to be done.
Next up was the power steering line. I brought the stock 72 high side line, and the 05 high side line to a locak hydraulic shop. The guy put a female swivel end on the 05 hose and brazed a male fitting on the 72 hard line.
Next up was the intake ducting. I choped off the little box off the bottom and fiberglassed up the hole with some extra glass mat and resin I had left over from the cluster project.
I then bought a K&N cone filter to attach to the MAF. Only one problem.... it was just a "fuzz" too big.
so I went to lowes and found something in the plumbing section that would work perfectly.
Allright guys, I need a break from my computer. I'll get to the rest later. I hope you enjoy.
1970 Datsun 240Z
1972 K5 Blazer Highlander
1972 Chevelle
1959 Apache 3100 SWB Fleetside
2006 VTX 1800f
Build thread:
http://67-72chevytrucks.com/vboard/s...ght=highlander
niceguy678us is offline   Reply With Quote
Old 09-12-2010, 04:07 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: 1972 Highlander 6.0/4L80E/LoMax
Cool project. Looking forward to the rest of the build
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-13-2010, 10:03 AM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Very nice, I have a 2000 6.0 that i'm putting into my '71 so this is a great reference, thank you for posting this. Looks good, can't wait to see it run.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-13-2010, 10:40 AM   #4
niceguy678us
I'm driving it every day right now. I'm just getting some time to put all of this stuff into a post.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 09-13-2010, 11:41 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
Nice! I really like how you married the new with the old. I'm attempting the same thing but with a 5 speed. I think we would all like to see some more pics of your Blazer.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-14-2010, 12:06 AM   #6
niceguy678us
Thank you for the compliments, I'll try and work on the rest of the info for the post tomorrow.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 09-14-2010, 12:40 AM   #7
old man jimmy
Looks super nice guy. One thing though. In the picture it looks like the pyrex part of your fuel filter is against the edge of your valve cover. Sure wouldn't want to see it go up in flames. Really like your dash cluster, good work.
old man jimmy is offline   Reply With Quote
Old 09-14-2010, 05:50 PM   #8
niceguy678us
For the wiring, I used the 05 under hood fuse/relay center. It was easiest this way because I wanted to utilize so many things from the 05 truck. I think it is easier to use the fuse box than it is to un-assemble and re-construct the engine harness to make it stand alone, but it doesn't look as neat and tidy. I had the complete dash harness, complete engine harness, and the rest of the plugs that went to the fuse center with about 6" of wire left on them so I could tap into them if necessary. I made some brackets to mount the box on the 72 fenderwell in front of the brake booster and ran all the wires through an existing hole in the firewall.
I ordered the re-pop drivers side battery tray from this thread
http://67-72chevytrucks.com/vboard/s...illary+battery
Since the 05 truck wiring was set up for the battery on this side already it just made everything easier, and I can wire up a second battery in the original passenger side tray later if necessary. I also mounted the ECU under this tray, just because that's how the 05 was set up originally and I didn't have to rebuild the whole wiring harness to move it inside the cab of the blazer (I will clean up the wiring harness, move the ECU, and try to hide the wires later on when I restore the body and frame).
For the Drive By Wire (DBW) pedal, I just made a metal plate that bolted to the firewall just like the stock 72 pedal assembly, and spaced the DBW pedal over to the left (it has a big "s" curve in it).
And I welded the 72 pedal to the 05 assembly
For the brake switch, you need a normally on(TCC switch signal for the ECU), and a normally off connection. So I used a 99-04 camaro brake pedal switch.
The camaro switch next to the 72 blazer switch.
The little grey plug with the orange and blue wires is the "normally off" part of the switch (connect these to the truck brake light wires from the old switch). Also remember that if you are adding the HND-3 cruise, you have to connect the light blue "CHMSL"(center high mounted stop lamp) wire to this part of the switch also so your cruise will disengage when you press the brake pedal.
The blue connector with the pink/white, green/white, pink, purple wires is the "normally on" part of the switch. I connected the TCC purple wire from the 05 brake pedal harness to the purple wire of the camaro switch. and spliced in the hot from an extra pink wire from the truck harness. The camaro switch fits EXACTLY like the stock blazer switch. It even uses the exact same thin metal nuts as the blazer switch.
Since I have DBW, it was just too easy to buy the Dakota Digital HND-3 and wire it up per ACKATTACK's thread here
http://67-72chevytrucks.com/vboard/s...d.php?t=398006
Here's mine (I even used the EXACT same relays with the pigtails, and I used 3 more of the same pigtailed relays for the electric camaro fan harness I made)
One difference though since I used the under hood fuse box. I just used the dash harness wires that ran to the steering collumn connector instead of the wires coming directly out of the TCM (they actually come from the C100 plug from the engine harness and follow inside the dash harness loom to the collumn connector). I also did this whith the ignition switch wires that ran to the column connector and the brake switch wires from the 05 brake switch harness.
Here are a few of the general things I learned about the truck fuse/relay box.
Make sure you put power to the fuse/relay box for the Ignition "0" circuit or your trans will not shift (stays in a "limp" mode). Ignition 0 circuit is normally powered back through the dash harness from the 05 under dash fuse box, so unless you are using the under dash fuse box in your swap, you need to replace this power signal. For this I just found an un-used pink wire from one of the under hood fuse box plugs and switched the pins (dissassemble the plug-slide the pins out-switch them-reassemble the plug-plug it back in).
Find all the pin-outs for your year engine/harnesses and print them out, your life will be a lot easier.
Don't get overwhelmed. Take it one circuit at a time, one component at a time, and before you know it, you'll be done. I finished all my wiring in a few afternoons once I got started on it.
Label all your wires you are going to use. I went to office depot and bought a box of 1000 3.5x15/16 "stick on" white address labels (was only a few bucks). These when folded in half around a wire, are just the right size to write a description on. You will never have to look up that wire again, so you can move on to the next one. Masking tape would work also.
Solder and heat shrink all your wire connections. Go to your local electrical supply store (not radio shack) and buy the good thick heat shrink. At my local shop it comes in 4 foot lengths and you just cut a little piece off as you need it. It takes a little longer to do things this way, but you won't have to worry about that connection ever again. And a loose connection will drive you crazy later when your swap is not running right and you don't know what to do (Learned this from my years in the automotive mechanic industry).
SEARCH-SEARCH-SEARCH. Every answer you need is on LS1TECH.COM, and LT1SWAP.COM somewhere, as well as this one. It will save everyone a lot of time, if YOU find the answers to your questions (not to mention more satisfying to know you did it yourself). What I mean by this is every time I went to search for something I had to troll through a few dozen dead end threads of people asking the same question I had with the only replies being.... SEARCH.
Here are a few pics of the truck I took today
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 09-14-2010, 06:02 PM   #9
k5hart
k5hart's Avatar
Very nice job. That dash cluster is awesome!
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 09-14-2010, 06:46 PM   #10
Thealien
Thealien's Avatar
Awesome build and write up. I am sure you have already helped a few people out!
Old 09-14-2010, 07:17 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
Old 09-15-2010, 07:42 AM   #12
niceguy678us
Well, I know I left ALOT out, but everyone's wiring needs are going to be different. The plug pin-outs are going to change depending on what year/type vehicle you get the drivetrain from. And everyone will not want to use all the donor vehicles components like I did.
I just basically wanted a new truck. I could have gone out and bought a brand new 2011 2500HD, but it's not what I really wanted. Ever since I was a kid, I've always wanted this body style blazer. So the swap was just to make it a reliable daily driver.
I don't think my blazer is anywhere close to some of the trucks, blazers, and suburbans on this site. I spent ZERO time doing anything cosmetic. Just a straight up engine swap for now.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 09-18-2010, 12:30 AM   #13
Cartoonface
Cartoonface's Avatar
I am about complete with mine too.....http://new.martymontez.com/?page=photos&s=&y=1&p=1
I had the same idea for the dash cluster. MAy as well...like you said, it goes with what's under the hood anyway. My gas tank is a mystery in that it was replaced by the original owner in '74 with this HUGE 37 gal tank made of 3/16 inch steel. (heavy). Eventually I'll rebuild another like it with the in-tank pump. ( I can't stand the noise. It's embarrassing at a stop light)
one question...how long did it take you to write that first (awesome) post???? ( which is why I sent you a LINK instead...)MArty
Cartoonface is offline   Reply With Quote
Old 09-24-2010, 04:39 PM   #14
niceguy678us
Sorry it took me a while to get back to you Marty, my computer took a poop. Well I had to download all the pics to photobucket, that took about an hour (I didn't use all the pics I uploaded). Then typing and pasting pics took about 45 minutes including flipping through my notes.
I hope I didn't come across too harsh with the "search" comments. If there is anything you want to know you can ask me.
Thank you for checking out my thread.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 09-24-2010, 05:35 PM   #15
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
You deserve a Medal for all the kind hard effort you put into this thread, so thank you!
Boy... you sure make me feel like a lazy good for nothing though.
Tom Vogel is offline   Reply With Quote
Old 09-24-2010, 07:46 PM   #16
Pop's C-10
Pop's C-10's Avatar
nice fab work
Pop's C-10 is offline   Reply With Quote
Old 09-25-2010, 02:05 PM   #17
Big J
Its lookin' like a Blazer!
Big J's Avatar
Nice!
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 09-25-2010, 02:53 PM   #18
1LoC10
Insert Title Here
1LoC10's Avatar
awesome work, good job on everything..... I think for the gauge cluster, instead of building another one down the line.... just go to HomeDepot and get some of that sone/gravel style rattle cans and spray it.. that way it will cover the little wavyness and it will look kind of stockish
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 09-25-2010, 11:01 PM   #19
niceguy678us
I used the rustoleum (speckled textured stone look) stuff to get the texture back, then top coated over that with flat black. I included the part numbers for the cans in my first post.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 09-26-2010, 10:56 PM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice write up and thank you for the info..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-28-2010, 07:36 PM   #21
DANTES JIMMY
DANTES JIMMY's Avatar
Dude awesome thread and a special write up this is a great project with wonderful details and with a really neat project nice job on the swap and the blazer i will be looking for updates on this one
DANTES JIMMY is offline   Reply With Quote
Old 09-29-2010, 10:50 PM   #22
Yukon Jack
Post Whore
Yukon Jack's Avatar
Very impressive!!!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-02-2010, 07:20 AM   #23
vtblazer
vtblazer's Avatar
Very cool thread to come across after being MIA for awhile, way to mix the two eras together.
vtblazer is offline   Reply With Quote
Old 11-11-2010, 05:01 PM   #24
Hart_Rod
Hart_Rod's Avatar
Sweet looking conversion. You might want to throw this in the truck section for all the 4x4 guys.
Hart_Rod is offline   Reply With Quote
Old 11-11-2010, 06:24 PM   #25
rsavage
rsavage's Avatar
Superb job! You are gifted.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
