09-12-2010, 09:16 PM | #1 |
5 lug bolt patten
I have a 89 Burban with a 5 lug bolt patten how hard is it to change to a 6 lug patten???????
Rakkasan 4 life |
09-12-2010, 10:36 PM | #2 |
67-72 parts collector,…
Re: 5 lug bolt patten
Swap the axles and brake drums from a 4x4 rear axle.
The front can be done with a set of aftermarket 6-lug rotors that are used on the 67-70 disc brake conversion kits. Early Classic Enterprises is a good source for the rotors. Just make sure your rotors are the 1.25" wide version, and it will be a bolt on.
09-13-2010, 06:53 PM | #3 |
Thanks Bro for the info but >>>DAMN do I have too swap the axle.......lol
Rakkasan 4 life |
09-13-2010, 07:17 PM | #4 |
http://67-72chevytrucks.com/vboard/s...ight=6-lug+2WD dont no if this will help good luck
09-13-2010, 07:54 PM | #5 |
I think you can just swap the two axles out of a 4x4 rearend and slide them into your housing.
