09-14-2010, 11:25 AM | #1 |
Got a Vortec....
my buddy lost oil pressure in his vortec the other day...still ran and no knocking just lost all the oil pressure, so he bought a crate motor. well i got the old motor for helping put the crate in, I am going to rebuild it and put it in the burb, and leave it TBI so i need some info... I think I am going to put headers and intake on it and dress it up some. So any guys have any info on the parts i need, what headers and intake should i get, and want the biggest cam without giving me problems. alright guys give me some info....Thanks
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
09-14-2010, 10:51 PM | #3 |
Re: Got a Vortec....
Great score, get ready to spend some money
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! |
09-15-2010, 01:57 AM | #4 |
In the Forgotten far North.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
09-15-2010, 02:26 AM | #5 |
you can get a good vortec carbed intake and tbi adapter for less than you can buy a tbi vortec intake for..
a vortec with no oil pressure.... yank that pan before you spend a penny... i've thrown many vortecs away from oiling issues.. either rods/cranks or mains... they seem to go like 5.4L fords go through cam towers.. i say this as no oil pressure is a good sign that your mains are done as well.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
09-15-2010, 07:35 AM | #6 |
Stock LT4 cam works fine, won't even need mods to the heads. I'd still upgrade the springs, though - GM's stockers aren't very good. Spend a few minutes blending the bowls and cleaning up the short turns, particularly the exhaust, and you'll pick up 15-20hp.
Flat top pistons and those heads will yield just a hair over 10:1 which is fine for a computer controlled engine. As long as the crank and rods are useable, they're fine as well, have the big ends of the rods checked and if they need to be resized, add some aftermarket bolts while you're at it. Watch sleazebay for a GM intake, it's made for the swap and will handle EGR, etc. with no problem. If you opt out of EGR, SDPC carries the block-off plug. USE THE FEL-PRO INTAKE GASKETS WITH COMPRESSION STOPS!!! |
09-15-2010, 10:24 AM | #7 |
cool thanks for all the info guys!
09-15-2010, 12:32 PM | #8 |
hey got another option today, buddy has a wrecked truck with a 5.3, which would be a better route?
09-15-2010, 01:13 PM | #9 |
Garage wrench
Personally, I would go the route of the 5.3 LSx engine. The old sbc engines are fine but the LSx platform of engines makes more power/torque and wayyy better mileage. Since you're spending money, do it right. It will be a good winter project. Take a look at some of the build threads on here, the swap is not that hard at all, it's just an involved process.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
09-15-2010, 04:37 PM | #10 |
should i keep it FI or just carb it?
09-15-2010, 05:45 PM | #11 |
FI is more reliable, but carburated is cheaper up front. The mileage advantage that the FI system will provide will more than pay for the additional initial investment over time.
And, I say go with the 5.3L, especially since you have access to the donor truck. |
09-15-2010, 08:04 PM | #12 |
5.3 IMO and keep the FI for the long haul. Plus I think it just looks killer in a square.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
09-15-2010, 08:08 PM | #13 |
Garage wrench
deff. keep the fuel injection. It's worth it's weight in gold. Esp. when you compare that system to a carb'd setup. And again, it's not that it's harder, it's just more involved. And all that means is that it requires more research and planning. DO IT!!!
09-16-2010, 07:23 AM | #14 |
Keep in mind that if you keep the 5.3 injected, you'll need speed sensor inputs from your tranny along with a few other things. MSD makes a box that'll run it carb'd, but you'll need TPS, VSS, etc. also. You'll probably want to use the donor tranny to make it a lot easier, IMHO.
Unless you have access to someone who knows what they're doing with injection or you can pull EVERYTHING from the donor truck, you'll probably be better off sticking with the Vortec, it's an easy carb/distributor swap. As for the injection and swap paying for itself over time, it depends on how much you drive the truck. I know a lot of folks with the 5.3 and 5.7 that get no better mileage than a well tuned 5.7 Vortec. Even if you pick up 2 - 5 mpg, that'll take a long time to pay for the investment. I won't mess with LS swap with anything smaller than a 6.0L, just not worth it IMHO. Now take a 6.2 with those big square port heads, stroke it, and then you REALLY have something!!! Last edited by BigBlocksRule; 09-16-2010 at 07:35 AM. |
09-16-2010, 07:30 AM | #15 |
5.3 all the way!
and keep the injection!
CHEVY ONLY Last edited by joe231; 09-16-2010 at 07:30 AM. |
