Old 09-24-2010, 08:06 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
73-87 LS Swappers
What headers are you using?
How much has the "extra" stuff cost you to do the swap?
What all do I need?
Motor, trans, ecu tune, exhaust, fuel system upgrade, mounts, and ????
I have been planning a 383 build, but for the price of the 383 build I think I can do the 6.0l swap depending on the $$ of the motor. Advise me please.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 09-24-2010, 08:51 AM   #2
MONTEZ
Re: 73-87 LS Swappers
What all do I need?
There are too many varibales to say.... Depends on how stock you leave it and what quality of parts you want to use for the build. Not counting engine and trans price, I've seen them done for under $1k. This also depends on how much of the work you can do yourself. I haven't even got everything I want yet and I'm getting close to $7k.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 09-24-2010, 09:57 AM   #3
softballnrd27
I plan to keep it pretty stock for the time being and then adding bolt-ons as time and $$ allows. I just want to get it in the truck and running for the lowest price possible. No ac for now until I get all the other ac pieces together. My budget is between $1500-$2500.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-24-2010, 10:26 AM   #4
MONTEZ
Expect to spend $1k on an engine and harness with ecm. If you get it cheaper, even better. You'll have to modify the harness or get it done for around $500. You can get motor mount adapters under $100. Use the stock manifolds on the engine for the time being. Try finding an engine with the accesories on it, that can save a good bit.
Old 09-24-2010, 11:44 AM   #5
softballnrd27
Should I run a 4L60 or 80 behind it? What came from the factory behind the 6.0l in the HD trucks?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-24-2010, 11:55 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
4l80e mostly came with the 6.0 until you get into the newer truck 2007 I think. You could do a nice build with a 700r4 as long as your not pumping 600HP.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-24-2010, 02:14 PM   #7
softballnrd27
I am trying to find a "complete" package and I would like to have a trans that can stand up to some abuse.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-24-2010, 03:01 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
then get a iron 6.0 with a 4L80e or 6L80e behind it
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-24-2010, 04:28 PM   #9
softballnrd27
That's what I am looking for I was just curious as to what came behind most 6.0l is all. Just a curious question, what does it take to adapt a th350 to a 6.0l?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-24-2010, 04:41 PM   #10
softballnrd27
Anybody use the Schoenfield headers? If so what is your opinion?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-24-2010, 05:59 PM   #11
68GMCCustom
an adapter. it compensates for the shorter crank end.
Kurt -
Old 09-24-2010, 06:05 PM   #12
softballnrd27
The adapter goes between the flexplate and the T/C or the flexplate and the crank?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-24-2010, 06:08 PM   #13
raycow
A special "deep dish" flexplate is available to make up for the reduced crank stickout. You can also use a spacer with the stock flexplate, but then you need a special starter.
Ray
raycow is offline   Reply With Quote
Old 09-24-2010, 07:06 PM   #14
68GMCCustom
Ray
since the ring is on the outer edge...how would a deep dish not move the ring gear out past the stock position...causing the same starter issue?
Kurt -
Old 09-24-2010, 09:00 PM   #15
raycow
Sorry, I worded that badly. The flexplate is used with a spacer and the ring gear is offset so it stays in the stock location relative to the starter.
Ray
Old 09-24-2010, 11:11 PM   #16
85burb
85burb's Avatar
Advaced adapters sells kit with flywheel and bolts and converter snout hub for like 170 or so. That is where i got mine. I am using the built 700R4 i have but going carbed route.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 09-25-2010, 05:43 PM   #17
softballnrd27
What do I use to get a VSS signal to the pcm if I use my current th350?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-25-2010, 06:22 PM   #18
68GMCCustom
you have to disable it I think?
Kurt -
Old 09-25-2010, 07:05 PM   #19
softballnrd27
Don't you need that for the ecm in order to drive? I thought I read about it on another forum. It really just depends on what the cost of the 6.0l/4l80e combe ends up costing. If the 4l80e jacks the price up too much then I will use my th350 for now.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 09-26-2010, 12:40 AM   #20
bark
subscribed!!!! I am starting to collect parts for a swap in my 77 stepper and have all the same questions,
I just picked up an 04 2500 sierra with a LQ4 and a 4L80E, but its a 4x, so now need to find an output shaft and a tail housing. but while I'm in there maybe I could mod it some????
There sure is a ton of info on here, its actually overwhelming, all the different routes you can take.
bark is offline   Reply With Quote
Old 09-26-2010, 01:48 PM   #21
68GMCCustom
I think I was thinking of the VATS. Got this off LT1 site.
VSS - If using a non electronic trans, You should KEEP a vehicle speed sensor regardless of what transmission type you use. The PCM needs to know if vehicle is moving. Without the speed sensor, you can suffer from reduced fuel economy, reduced power, and idle problems. There are a few options for speed sensors on the transmissions with cable drive output. View this link at Dakota Digital website. I have used Dakota Digital SEN-4160 with good success. This is a 8000 pulse per mile sensor, that will allow cable speedometer hookup. I can program any PCM to accept any # of speed pulses. (1996, 1997 Black Box Vortec PCM will not accept 8000 pulse input)
not sure of a VSS work around or if its possible...might check ls1tech.com
Kurt -
Old 09-26-2010, 06:25 PM   #22
kSStamp0182
LSX addict
kSStamp0182's Avatar
i am converting a 4x4 to 2wd too. i found the reluctor ring and speed sensor on this site (after HOURS of searching the web). http://www.transmissionpartsusa.com/
kSStamp0182 is offline   Reply With Quote
Old 09-26-2010, 08:26 PM   #23
Juiced06GTO
Easiest way to get a vss signal is with the dakota digital spedometer cable vss generator. I need to dig up the part number, but that is what I just did with mine. It outputs an 8000 pulses per mile signal that you wil need to update in the PCM once you get it running.
Juiced06GTO is offline   Reply With Quote
Old 10-05-2010, 02:25 AM   #24
love my 72
love my 72's Avatar
does any one know of a motor mount adapter that will allow you to retain the A/C compressor in the stock location? is that even possible?
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
Old 10-05-2010, 11:32 PM   #25
Puglia10
^x2!
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
