Old 09-25-2010, 04:44 PM   #1
67Slider
67Slider's Avatar
69 Camaro Gas Tank Install
I have been wanting to install a behind the license plate tank since I bought my truck. I took this as an opportunity to help anyone else who may want to go this route.
Mods - If this need to go someplace else - no problem with me.
Here goes.......
I bought a 69 Camaro gas tank(18 Gallon), sending unit, straps and anti, squeak kit from a company off of E-bay by ther name of Tamraz for 194.00 shipped. Don't order off ebay, just call the company tell them about the forum and this install and they "may" cut you a deal. Don' bother with the 69 Camaro gas tank straps. It's easier to fabricate your own than use theirs. See if they will swap out the straps for the anti-squeak kit.
Their # is 1800-442-4601
Here is a list of other items needed:
Flip down license plate holder - 10.00 U-pull
6 ft metal tubing 2"x3" and 8' of 1"x 1/8 strapping - $30 at steel distibutor
10' 3/8 tubing, 4' rubber fuel line, locking gas cap, union for tubing - 32.00 @ Autozone
Misc hardware to mount tank to frame and fuel line - $10 at hardware store
Total about 276.00
[IMG][/IMG]
I started by mocking up the tank to the frame to see how much of a spacer I would need with my bumper
[IMG][/IMG]
[IMG][/IMG]
Once I got the right height I took off the license plate bracket and cut out a square with the cut off wheel, drilled a couple of holes in the bracket and mounted the flip down holder.
[IMG][/IMG]
I cut the 2x3 square, drilled the holes and mounted it to the frame. After that I cut the 1x1/8 and bent them into the shape of the tank, drilled holes and did a test fit.
[IMG][/IMG]
Put everything in place and slid the anti squeak pieces in, tightened it all down.
[IMG][/IMG]
Took out the old tank and fuel lines and pre-bent the new lines to match the old one.
[IMG][/IMG]
Then installed the front portion using the old clips. Installed the back portion with some new clips and hoses.
[IMG][/IMG]
[IMG][/IMG]
I still need to hang the exhaust so that it doesn't hit the tank and smooth the old gas neck hole but that will be another day.
Here is the finished product.
[IMG][/IMG]
I have to say thanks to Bad70sbchevy, without his pics and info none of this would have gotten done. This is truly his build I just detailed it a bit more.
I took a bunch more pics and they are in my gallery if you want to check them out.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 09-25-2010, 04:49 PM   #2
shaneschevys
Its always something!
shaneschevys's Avatar
Re: 69 Camaro Gas Tank Install
I never thought of using a camaro tank. Thanks for sharing!
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 09-25-2010, 04:54 PM   #3
69 Okie Truck
69 Okie Truck's Avatar
How well does it fill?
69 Okie Truck is offline   Reply With Quote
Old 09-25-2010, 05:10 PM   #4
71red
71red's Avatar
AWESOME! Thanks for the write up and pics. I plan on doing this as well. . Very clean!
71red is offline   Reply With Quote
Old 09-25-2010, 05:25 PM   #5
67Slider
67Slider's Avatar
Just filled it and it fills great.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 09-25-2010, 05:54 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
so thats the original filler area? Does it leak or anything?
John
1999 Toyota Tacoma 4x4
Old 09-25-2010, 06:03 PM   #7
Kidd-7
Kidd-7's Avatar
Thats sweet; I grew up with a '79 TA in the family and thought that was the coolest thing at the gas pump. I have another idea to add to the list . Any concern with ground clearance it looks kinda low. What is the ride height of your truck? Thanks.
Kidd-7 is offline   Reply With Quote
Old 09-25-2010, 06:09 PM   #8
LONGHAIR
A whole lot of '60s to mid '70s GM cars were like that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-25-2010, 06:18 PM   #9
67Slider
67Slider's Avatar
I have a 4 inch drop in the back. Doesn't sit any lower than the pumkin.
No leaks!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 09-25-2010, 08:26 PM   #10
57larry
that's a great idea. let's put this in the tech section
57larry is offline   Reply With Quote
Old 09-26-2010, 10:32 AM   #11
RCbowtie69
RCbowtie69's Avatar
looks great,nice job, and pictures
RCbowtie69 is offline   Reply With Quote
Old 09-26-2010, 04:18 PM   #12
72armyswbtruck
72armyswbtruck's Avatar
I wonder what other years that 69 GM Camaro tank will interchange with??
Always looking for a different source for a part. Camaro equals expensive, 78 Nova equals not so expensive.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-26-2010, 04:46 PM   #13
norman martin jr.
norman martin jr.'s Avatar
What a great idea.Been kickin around what to do with my. This is the best one so far. Tank out of the cab and still has a factory look. Nice install. Thank for sharing...
Mr. Breeze
norman martin jr. is offline   Reply With Quote
Old 09-27-2010, 02:43 PM   #14
Bad70sbchevy
Bad70sbchevy's Avatar
Thanks man, that thing turned out clean. Great job.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 09-27-2010, 07:54 PM   #15
Rodk65
Rodk65's Avatar
Good write up and pictures. I'll have to do some measuring to see if it will clear a short bed 4x4.
ROD
1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C.
1971 C20 Camper Special. 350/350. SOLD
2002 Chevy Tahoe LT
Rodk65 is offline   Reply With Quote
Old 09-28-2010, 02:41 PM   #16
djimenzj
67Slider thank you for shareing... Im on a low budget and will have to go this route... Nice set up vs the 700 fuel cells... hey they stick out too... still looks clean... Nice work ! ! ! Having the tank in the cab makes me nervous... especially cause our trucks tend to get t bonned... nock on wood... Thanks again 67Slider !
djimenzj is offline   Reply With Quote
Old 09-28-2010, 08:26 PM   #17
slowtruck
WOW! I like the look, give a factory look to it. I've already installed the blazer tank, but had I seen this first I would have done this. It would have saved me the hassle of putting a gas door in the side of the bed!
slowtruck is offline   Reply With Quote
Old 09-28-2010, 08:44 PM   #18
lakeroadster
Great write up and initiative to try something new!
Do you have any pictures of your Camaro tank installation from the side or back, from a distance and with the bed installed? Seems like the tank is hanging down really low... same look as the blazer style tanks.
I recessed a 1949-52 Chevy tank into my '65 'cause I really didn't want to see the tank hanging below the bumper or visible from the side of the truck.
lakeroadster is offline   Reply With Quote
Old 09-28-2010, 09:01 PM   #19
67Slider
67Slider's Avatar
I haven't put the bed back on. It is still in the "in work" stage. I wil try to take some pics from the side tomorrow.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 09-29-2010, 06:36 PM   #20
Bad70sbchevy
I got some pics of the back of mine with stock lift.
Old 09-29-2010, 06:54 PM   #21
Rodk65
Rodk65's Avatar
That looks nice Bad70. I think I might try this instead of a putting a hole in the side or in the bed.
ROD
2002 Chevy Tahoe LT
Old 09-30-2010, 07:39 PM   #22
Bad70sbchevy
Thanks, thats the exact same reason why I didnt want to use the blazer tank.
Old 10-04-2010, 05:32 PM   #23
Texasbigblock
Texasbigblock's Avatar
That is almost exactly how I did mine, been a few years and still works great!
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 10-05-2010, 09:53 AM   #24
Bad70sbchevy
Its funny you should say that, I actually got the idea from your build thread
Old 10-05-2010, 01:13 PM   #25
lakeroadster
I took the liberty of lightening up the picture a bit so the tank could be seen in the photo... man that is one shiny bumper :-)
