Old 09-27-2010, 04:46 PM   #1
shenk10
shenk10's Avatar
LQ4 vs LQ9
What is the difference between the lq4 and the lq9? Is one considered better than the other? And which would be a better swap?
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 09-27-2010, 09:13 PM   #2
85burb
85burb's Avatar
Re: LQ4 vs LQ9
I think the only major difference is the pistons. Not 100% on that tho..
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 09-27-2010, 11:07 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: LQ4 vs LQ9
....yup and that brings comprssion to like 10:1 for LQ9 vs LQ4 at 9.4:1
( I think those #'s are right... or at least close)
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-28-2010, 09:11 AM   #4
menace121978
menace121978's Avatar
Re: LQ4 vs LQ9
...and brings horsepower from 320 up to 345 or so.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-28-2010, 11:17 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LQ4 vs LQ9
dished vs flat top pistons is pretty much the only difference. Swap would be 100% the same. Which is better? thats a toss up.
Lq9 comes with slightly higher hp, but usually incurs a slightly higher price for the motor. Lq4 is a 9.4:1 cr, which is preferable if you want to keep the cr #'s low for FI or large shots of spray.
Even if you wanted an N/A combo, you may be able to get an lq4 and a milled set of heads (to bring your compression up) for less or close to the cost of an lq9...all depends on the source.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-28-2010, 11:43 PM   #6
djw32
Re: LQ4 vs LQ9
Either motor should work for your application.
djw32 is offline   Reply With Quote
