Old member
Had to take the thrid door apart to open it. The handle broke off. From what I have found out it's a pretty common problem with them. Has anybody found a fix for it other than buying a new handle. I plan to take it to work and have a billit handle made for it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Trucks N Tranzams
Re: 2002 s-10
There are several available to replace the cheap plastic handle.
Here are are some links to consider: http://cgi.ebay.com/ebaymotors/Third...Q5fAccessories http://cgi.ebay.com/ebaymotors/QUALI...Q5fAccessories It also helps to to unload the door prior to pulling the handle to open it. Hold the door closed with moderate force then pull the handle to unlatch it.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" Last edited by Arad68; 10-03-2010 at 12:53 PM. |
Old member
Arad68,
Thanks for the links. I bought a complete replacement this morning at O-Riley's with life time warrinty for $11.00. Can't beat it. ![]()
