I have the shorter axle that chevy made, it measures about 44" from brake backing plate to plate. The question is: What is the backing plate to plate length on the wider track axle? Also what is the distance from the center of one leaf spring pad to the other? The target group for this would be from 81-87 trucks that were produced as true duallies with bed and flared rear fenders. All info would greatly be appreciated.
69'Chevy 1 Ton Narrow Track Duallie |
Im not sure of measurments but just wanted to point out that a friend of mine swapped to wide duals and he cut his inner tires up when loaded. Make sure to look at that too.
CoryM ------------------ 1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada FWD SUCKS!http://www.geocities.com/chevroletc1070/
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
It just doesn't matter
![]() Join Date: Apr 2001
The reason he cut up his tires is that you have to trim the wheel arch out just like Chevy did on the wide duallys...Also Chevy made these wide duallys from as far back as 75 I believe...I know there is a width difference, but since I don't have my "new" truck here yet, I can't tell you the measurement...
------------------ 72 GMC Crew Cab.....SOON TO BE 67 Chevy look a like....and a DUALLY eventually...
05 Chevy Silverado..... A rogue BMW guy.... If you don't like me- TAKE A NUMBER; There are people ahead of you!! |
