Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-17-2010, 09:31 PM   #1
brans72
harbor frieght blasting cabinet?
I was wondering if any one here had the blasting cabinet from harbor frieght? Any do's or don'ts? tips to make it work best? Have a reclaimer on it? Whats the biggest car part you hve fit in it wheel?
brans72 is offline   Reply With Quote
Old 10-17-2010, 11:25 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: harbor frieght blasting cabinet?
Wheels are hard to do in it. Make sure you brace the legs. The legs on mine with 40# of grit and some parts laid down like a camel. I had to empty it and cross brace the legs. Do get a reclaimer and do get an air dryer otherwise it shoots mud at your parts.
dwcsr is offline   Reply With Quote
Old 10-17-2010, 11:58 PM   #3
red69ss
Burnouts are therapeutic
red69ss's Avatar
a vaccum system is almost a neccesity with a cabinet,I see guys using a shop vac for this, not sure how well that works though. they say you have to use caulk to seal up the seams on the HF cabinets, I was considering one of these but found a quality used one on craigslist for $400 with the vaccum system. good luck
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 10-31-2010, 10:27 AM   #4
Shane
Shane's Avatar
replace the pickup tube and gun with the retro-fit-kit from TP Tools and then purchase a tube of silicone and caulk EVERY joint.
makes it almost perfect for about 1/10th the cost.
Shane is offline   Reply With Quote
Old 10-31-2010, 12:02 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have had mine for 5 years now and never had to caulk or seal anything. Its been a very tight unit. If you use a vacuum on it even if it does have some leaks air would be moving into the unit not dust out of the seams. My only issue was the weak legs
Old 10-31-2010, 01:29 PM   #6
Shane
Shane's Avatar
count yourself lucky if you don't have leaks ... EVERYONE i know that has bought one of these uses a vacuum and still had to caulk the joints.
Old 10-31-2010, 01:57 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Which one do you have
http://www.harborfreight.com/cpi/cta...emnumber=42202
or
http://www.harborfreight.com/40-lb-c...net-93608.html
I hear a lot of issues with the first one, leaks and the like.
Old 10-31-2010, 07:45 PM   #8
Shane
Shane's Avatar
2nd one ...
Old 10-31-2010, 08:46 PM   #9
dadsworktruck
i have the second one too, i made me a water bong style air filter for a small vac system, works ok, i used a too flimsy bucket for water, want to move too much and fill my vac at times, my issues for me is lighting, i am going to somehow add an extra light into it , and brace the legs and raise it up, hurts my old back i am 6'2, cant stoop over as well as you young folks. i am just a newb at all this but enjoy playing, now if i could only get back to actually working on my rust bucket..
dadsworktruck is offline   Reply With Quote
Old 11-09-2010, 12:37 AM   #10
dammitmitchell
the pollock
dammitmitchell's Avatar
we have two in my aviation school.
they are awesome for the price.
.. better then making one of our own i guess...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-15-2010, 10:41 PM   #11
eldogg
eldogg's Avatar
I have one also. I caulked mine and put some casters on it. Works great.
eldogg is offline   Reply With Quote
Old 11-18-2010, 11:15 PM   #12
brans72
I think I wanna up date gun and get a foot pedal also not sure if I got to much of a vaccum on it but it makes the gloves swell up from h%ll when I cut it on and hard to work. Manual say only 10 lbs on media but I wanna try ading another 5 and see what happens. What media are you guys using? I am playing with some play sand right now since cheap but open to other ideas. Brandon
Old 11-19-2010, 06:05 PM   #13
red69ss
red69ss's Avatar
the foot pedal is great. you need to get a different media, you are not suppose to use sand in a cabinet because the dust can cause silicosis. I use aluminum oxide or glass bead depending on what I'm blasting.
1969 CHEVELLE SS
Old 12-08-2010, 05:41 PM   #14
allengator
allengator's Avatar
I have the second one, use my shop vac....
Didnt caulk anything... works great, but nozzle clogs constantly if the air isnt dry!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-14-2010, 09:10 PM   #15
brans72
any one found something better for view then what they give you? Has anyone installed a foot pedal set up on theres?
Old 12-14-2010, 10:14 PM   #16
cdowns
cdowns's Avatar
play sand is poor for blasting,due to the fact it is tumbled to b smooth and not cut little knees// blasting sand has sharp edges for cutting// but sand isnt good in cabinets//play sand sometimes will have trace salt deposits in it too depending where mined
i use commercial black beauty stuff if holds up well for a long long time cuts fast
i personally like bigger blasting cabinets that i can load up with more and biggger stuff// usually load 3intakes and a couple pair of valve covers in mine when i get to blastin
Old 01-01-2011, 10:36 AM   #17
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I know this thread is kind of dormant, but I was reading it and thought I'd add a few thoughts...
I do a lot of powdercoating, so consequently, I do a lot of blasting. Let me say that again, I do a LOT of blasting.
A blast cabinet is nothing more than a bunch of consumables bolted together. If you use it quite a bit, you're going to find that lots of parts will wear out.
I use the 40 dollar tips and they still wear out. Even the gun wears out internally every year or so. I change lens protectors several times a week. I change lenses twice a year or so. Even the pickup straw that goes down into the media wears out.
Why do I go to the trouble to say this ? Because you must have a source for these parts if you have any hope of keeping your cabinet working well. I cannot imagine Harbor Freight being very helpful in that area.
I use TP Tools stuff, which is made in the USA. I can call them and they will ship any components I need that same day. Believe me, I'm not trying to be an elitist either. You can buy a real good TP blast cabinet for under 400 dollars and it will last you for the rest of your life. Figure in some periodic part replacement and you've got your blasting needs covered. In my opinion, this is one area where spending a little more up front will pay large dividends in the long run.
Old 01-01-2011, 12:36 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Tx Firefighter View Post
I use TP Tools stuff, which is made in the USA. I can call them and they will ship any components I need that same day...
Wheres a good place to buy a TP Tools cabinet?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-01-2011, 01:10 PM   #19
cdowns
cdowns's Avatar
www.tptools.com is where to buy or they setup at some of the major swapmeets around the country and have good show specials
Old 01-01-2011, 05:07 PM   #20
Tx Firefighter
You won't be sorry with TP Tools. They are one of the old-school companies owned by real folks.
Old 01-02-2011, 10:29 AM   #21
KSCHEVYUP
KSCHEVYUP's Avatar
TX Firefighter is giving out some really GOOD ADVICE!
I wish I had thought of this before I bought the blast cabinet I have.
The parts do wear out as he stated; and then where are you going to get replacements; such as nozzles;glass and light covers;etc.
Just my .02 cents worth.
Ron
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 01-02-2011, 06:16 PM   #22
Shane
Shane's Avatar
I've bought replacement parts for the el cheapo Harbor Freight cabinet from TP Tools.
Old 01-03-2011, 08:47 AM   #23
cdowns
cdowns's Avatar
a quality cabinet was my choice. can load 2-3 wheels or 4 manifolds at once in it and get to do serious work
Old 01-03-2011, 11:28 AM   #24
Mike Bradbury
Mike Bradbury's Avatar
I have the floor mount cabinet from HF and it seems to work well, If I owned a business of sandblasting then this unit would not do. But for the home hobbyist then it suffices. I have had to replace the nozzles several times and getting ready to replace the gun also but sounds like that is normal for even the expensive system.
One thing I have done is to get a dedicated shop vac for the cabinet. The dust gets all stuck to the ridges in the vac line and the inside of the vac will never be the same. I run two dryers on the compressor. One at the compressor and one at the blaster.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 01-11-2012, 12:02 PM   #25
Zumo
Hot Rods For Life
Zumo's Avatar
What compressor are you guys using in your cabinets? We need to get one for ours and am looking for something in a 60-80 Gallon range with CFMs around 11-15?
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
