Old 10-20-2010, 07:03 PM   #1
72 GMC
lt1swap.com
Has anyone here ever used lt1swap.com for any wiring harness modifications or pcm programing? If so, how was your experience dealing with them?
72 GMC is offline   Reply With Quote
Old 10-20-2010, 08:18 PM   #2
nomrlz
nomrlz's Avatar
Re: lt1swap.com
a guy i know used them for a harness and was happy with them
nomrlz is offline   Reply With Quote
Old 10-23-2010, 08:14 AM   #3
menace121978
menace121978's Avatar
Re: lt1swap.com
i've heard nothing but great things about their harness. thats the route im going on my next one. member 1972SuperCheyenne (Josh) used them and was very pleased with the workmanship
here's a link to his build http://67-72chevytrucks.com/vboard/s...13#post4254813
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-23-2010, 10:33 PM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: lt1swap.com
The harness I bought from them was the nicest quality aftermarket harness I've ever used. It fit so well once I had it installed on my 6.0 you could barely even tell it was on there!
--Josh
Old 10-24-2010, 12:33 AM   #5
tonypaul
tonypaul's Avatar
Re: lt1swap.com
Brendan at lt1swap.com did my PCM reprograming. He came highly recommended by a friend of mine....
tonypaul is offline   Reply With Quote
Old 10-25-2010, 09:17 AM   #6
mrhino
Re: lt1swap.com
I used Brendan from LT1 swap. his web site was so full of information that I decide to do my own harness. it was relatively easy just took a little time and a quite place to think. Saved my self a bunch of money I could use for other things. (I think I spent about $6 dollars for a odb2 port, relays and a few terminals). Brendan also reprogrammed my PCM for $75 to all the things I was using and removed what I wasn't including, MAF. plus I sent him the PCM and he returned it the next day. I couldn't believe how fast he was. He also supplied me with some tech support. It is nice since of accomplishment knowing I did the harness and if I ever have problems I should be able to figure them out myself, but if not, I know Brendan will help me out. BTW it runs great!
check out his website. http://lt1swap.com/index.htm
mrhino is offline   Reply With Quote
