Old 12-22-2001, 05:01 PM   #1
doc70sub
doc70sub's Avatar
Post Blazer/Truck body swap....
Hey Guys,
I have a '79 Blazer w/ 400 SB, TH-400, NP-203, A/C, P/S, P/B, Tach, P/W, P/L, and oh yeah, a rusted top, quarters, etc. But I also have an' 83 C-10 P/U w/ a good body, so I'm thinking of swapping the newer cab/front clip onto the Blazer chassis. Anyone know of any problems that may arise? I'm doing away w/ the A/C, P/W, P/L in the process and will utilize a small flatbed. Thanks!
Doc
'70 Sub C-10
350/TH-350/3.73 12-bolt
Black-on-black
15x8 Rallys w/ 275/60/15
Soon to be lowered....
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 12-22-2001, 07:33 PM   #2
shepherm
Post
I think they have dif. frames. I had a 1984 blazer and the wheel base was shorter/longer then the swb truck. I really don't remember but I think there is a dif.
2001 Camaro SS 335hp (for now)
2000 GMC P/U
shepherm is offline   Reply With Quote
Old 12-22-2001, 08:04 PM   #3
doc70sub
doc70sub's Avatar
Post
shepherm,
I know the wheelbases are different, that's why I said that I was going to use a small flat-bed behind the cab. The Blazer frame is much shorter than even the SWB trucks, but I'm going to use this Blazer-hybris off-road mainly.
Thanks!
Doc
Old 12-22-2001, 09:06 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
try www.coloradok5.com
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 12-31-2001, 11:33 AM   #5
crossy
Oh,you can't buy that new
crossy's Avatar
Post
DOC, there are no REAL problems with this as you are changing cab& clip which makes the swap much easier. there is a slight mod to the front of the frame so you can mount the newer style bumper. Once you look at both you'll be able to figure it out.An air whizzer or sawzall will do it.may have to drill a hole or two , no biggy,DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 12-31-2001, 03:52 PM   #6
doc70sub
doc70sub's Avatar
Thumbs up
Thanks Crossy!!
Doc
