10-25-2010, 10:34 AM | #1 |
help getting 400-450 hp
ok i have already pulled my engine out and about to start braking it down.
i want to get atleast 400-450 hp on this engine. some guy told me i should get some vortec heads and that they would be good stock? i have an 86 block 350 of course! what do u guys i should get? im gonna need help on a setup on this engine. thanks! |
10-25-2010, 11:15 AM | #2 |
Re: help getting 400-450 hp
vortecs will not get you there.. maybe flywheel gross hp..
I'd look ad dart/afr/brodix 450 out of a n/a 350 is a tempermental beast.. you sure you can live with a set up like that |
10-25-2010, 02:39 PM | #3 |
an honest 400hp at the crank will even take decent heads if you keep streetable compression.
10-26-2010, 12:29 AM | #4 |
what heads u guys think i should go with?
i want to drive my truck around and when someone pulls up next to i want the power i need to beat them |
10-26-2010, 11:31 AM | #5 |
depends on budget. edelbrock performer rpm heads are decent street heads. i've seen lots of em used for $500-700 and they are legit 400hp. afr 185's are a better but then again will cost more. i would stay under 10.5:1 for premium fuel to be safe. people have run higher but cam selection becomes very important. also if you get some "bad gas" it could get ugly
10-26-2010, 10:22 PM | #6 |
so your saying 400hp would not take unleaded gas only premium?
what kind of pistons should i go with? my block is 40 over |
10-26-2010, 10:49 PM | #7 |
I would find the cam lifter head match up and go from there. i have 215 dart heads and standard stroke with high comp and do about 650 at the wheel,Call Kirk at bullet cams and he will figure you out a pack,what to do and I promise you won't be hurt at all!
Built chevy tuff! |
10-27-2010, 09:50 PM | #8 |
were can i find this kits?
10-28-2010, 02:14 PM | #9 |
Champagne Taste on Beer Budget
Jegs has them and Summit Racing as well as others out there.
Just remember the old hot rodders rule: "Iffin' you wanna go fast its gonna cost ya!" Good luck.
Coming Soon: Project 1970 Country Truck |
10-29-2010, 08:29 AM | #10 |
yea i knw its going to be really costly but im going to take my time on this engine and build it right!
its time to start saving |
10-29-2010, 08:27 PM | #11 |
will the stock crank shaft work with a kit around 400-500 hp?
what kind of pistons you guys think i should go with not to expensive tho? |
10-31-2010, 02:14 AM | #12 |
you can do all you want up top and i dont understand why everyone always thinks in that direction. but i personaly would run the heads you have and put a 3.75 inch crank in it with corosponding parts and a good cam. you can always build the top later. It is usally the best way to go for the street. like most have said on here a 350 pushing 400hp is going to be a beast... but in my opinion a mild build on a 383 will get you 400 ponys no problem...
later andrew K.
my build http://67-72chevytrucks.com/vboard/s...d.php?t=210902 Last edited by 57sailplane; 10-31-2010 at 02:17 AM. |
10-31-2010, 02:56 AM | #13 |
At the body shop.
No subsitute for inches
" That didnt make it any newer " " Dont antique the equipment " |
10-31-2010, 12:37 PM | #14 |
this is what kind of crank shaft i got
14088532 350 86-88 Truck Forged,one piece rear main seal im wanting to use the one i got cuz i think they cost to much! im having trouble identifing my head maybe u guys can help? this is the number i get off them..... 10147898 lmk guys and i need help on what to get for the engine? |
10-31-2010, 12:40 PM | #15 |
wait i made a mistake cranks are not expensive my bad
i just looked them up hahah ya im a rookie! so lmk what kind of setup u guys would do i mean everything in the engine i would appreciate it alot! thanks! |
10-31-2010, 02:48 PM | #16 | |
wide parting line or thin.? thin is cast wide is forged |
10-31-2010, 08:54 PM | #17 |
ok iv been looking allday at casting numbers trying to find it!
this is my engine num 10243880 on this site it says its a 95-00 years http://www.rapidomarine.com/default....sting_id_.aspx i always thought my block was an 86 block i always had carburated. arnt 95-00 fuel injected? im congused someone plz help |
10-31-2010, 09:33 PM | #18 |
Keep in mind, when you go with a longer stroke crank, you probably need to go with a new rod and piston as well to make everything work. But if you are going to do it, do it right. Make it stronger than your intended usage.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
10-31-2010, 10:33 PM | #19 |
Registered Truck Offender
& as you step up in demand for air, (stroke, rpm or cubic inches) you need to revisit cam, heads, intake carb, exhaust..... your motor is a 'combination' of parts that can work together, and compliment each other, , or cost power, $'s and headaches.
I'd suggest you settle on a 'plan' and work forward towards that end.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
10-31-2010, 10:34 PM | #20 | |
60-66 Nut
Yes the '95-00 350's were all fuel injected. But that doesn't mean you can't put a carburetor on it. Your block will have a date code on it. It will be located on the bellhousing flange just over towards the passenger side from where you found the 10243880.
10-31-2010, 10:59 PM | #21 | |
Should be a great 350 to start with. Those PM rods are good. |
10-31-2010, 11:30 PM | #22 |
dang and i always thought it was an 68 haha
ok guys but asking for a setup u guys would go with like wich pistons? cam? heads? or same heads i have? stock crank shaft? |
11-01-2010, 12:41 AM | #23 | |
http://cgi.ebay.ca/COMP-CAMS-SBC-MUT...item53e4389bb3 and if you get impatient get a strong crank throw it in and shoot it with a 200hp shot and prey she doesnt pop hahaha. but really man good luck well worth it to do properly. i was at 410hp before my roller build and even with the 410 it is a riot to see peoples jaws drop when you eat em ! special 5.0 stangs and any ricer out there :P haha |
11-01-2010, 09:55 PM | #24 |
ok so lets staart with the heads
u guys throw some at me? |
11-02-2010, 01:26 AM | #25 |
if you have the money i sware by brodix and AFR both are great! but if your short on $$$ you could always take your heads out take em to a machine or motorshop and have them port them out, polish em and have them set up for bigger valves
