Old 11-01-2010, 11:21 PM   #1
BardonRedDeath
pictures of my $800 72 stepside
nothing fancy but picked it up off of a farm and have not put much but a new distributor into it drives back and forth to work real nice
looking forward to doing more work on it with my dad since he is the mechanic teaching me how to do this stuff
im sure i will be asking alot of questions in the future (mainly when i have money)
BardonRedDeath is offline   Reply With Quote
Old 11-01-2010, 11:28 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: pictures of my $800 72 stepside
I'm not seeing any of your images...not sure why though
EDIT...never mind...there they are : ) I'd say you did extremely well for $800!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-01-2010, 11:28 PM   #3
BardonRedDeath
fixed sir
Old 11-01-2010, 11:36 PM   #4
dadsworktruck
Nice truck, welcome to 67-72's if it your first, there alot of nice folks on here that have seen it and done it all, so just dig into the faq section, the builds and every nook and cranny in between, i am new to this myself , i spend alot of time reading old post and the faq,s, but can't help but watch the nice builds too from time to time, so welcome from south carolina..
dadsworktruck is offline   Reply With Quote
Old 11-02-2010, 12:05 AM   #5
BardonRedDeath
I remember my first question was, there is alot of play in the shifter enough so that its hard to tell what geard you are in (when it is in drive it looks like it is in second and when you put it in reverse the reverse lights do not stay on unless you hold up on the shifter) is there an easy way to fix that?
im guessing there is no easy way to fix anything any help is appreciated
Old 11-02-2010, 06:52 AM   #6
cam.man67
cam.man67's Avatar
nice truck, looks well-patina'd.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 11-02-2010, 07:05 AM   #7
Pop's C-10
Pop's C-10's Avatar
not bad for 5 bills
Pop's C-10 is offline   Reply With Quote
Old 11-02-2010, 07:10 AM   #8
stich626
mine has the same issue..
stich626 is offline   Reply With Quote
Old 11-02-2010, 08:28 AM   #9
SSedan64
SSedan64's Avatar
Nice find & deal, love the short beds..
I had been looking at a 70 Fleetside SB not far from me. Guy was needing $$. Last time I went by, his house had burnt to the ground. His new 2005 Dodge Truck he had recently paid off & dropped the full coverage Ins on was parked between the house & the 70 SWB, . It got cooked. I told him at least the better truck won. Now He needs the 70 SWB for a DD. It did get hurt too bad, mostly just paint. Talk about Patina, nothing makes surface rust like fire.
I need to change my avatar:
SSedan64 is offline   Reply With Quote
Old 11-02-2010, 09:35 AM   #10
dadsworktruck
on your play in the trans linkage, check the rods from trans to shifting mechanism on steering column, the eyes and rods may be worn and any amount along the way will only add more play in the shifter, may have to add bushings, or reweld rod or resize holes, also check for free movement in and out on gear shifter also, lube roll pin at column to shifter handle.
