Old 11-04-2010, 03:18 AM   #1
1949gmc
What size lift do I have?
Could anyone guesstimate for me what size lift I might have here, if any? Is it a 2", a 4" or might it be stock? The 38" picture is from the garage floor to the top of the wheel opening on the right rear.
LEFT FRONT SPRING
LEFT REAR SPRING
FROM GARAGE FLOOR TO TOP OF WHEEL OPENING
1949gmc is offline   Reply With Quote
Old 11-04-2010, 08:28 AM   #2
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: What size lift do I have?
What size tire is that on the rear? Its been so long since I've seen stock, lol... Looks like maybe a helper spring has been added front and rear. If thats a 33 on the rear I'd say 2 if its a 35 maybe 3-4.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 11-04-2010, 08:56 AM   #3
1949gmc
This thing has four different wheel/tire combos on each corner. I think the originals were stripped off long ago and these were put on just so that it could roll around. That old BFG on the left rear only says that its a 12R15LT and it measures 31" tall. The right rear tire is also a 31.
Old 11-04-2010, 09:47 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here is a stock 3/4 ton front spring pack.
With weight on the axle it has a slight negative arch. I'm guessing you have a 2" spring pack up front.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-04-2010, 10:12 AM   #5
blue70k5
blue70k5's Avatar
Looks to me like you have an add-a-leaf up front and possibly stock in the rear...
blue70k5 is offline   Reply With Quote
Old 11-04-2010, 01:32 PM   #6
drunkbus
New Member
drunkbus's Avatar
Rear looks stock, front looks like someone added the bottom spring.
drunkbus is offline   Reply With Quote
Old 11-04-2010, 03:54 PM   #7
1949gmc
So, its not much of a lift at all, then. I mean, its higher than factory, but it's not any kind of a lift kit. I ask because I have to change a front spring because of this:
Old 11-04-2010, 05:01 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yikes!!
