Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 11-08-2010, 08:07 AM   #1
DHPmike
DHPmike's Avatar
Tie rod ends
Im wondering what other tie rod ends for the S-10 spindle. I need to make a set of notchless for a guy that works with me. I know theres others that fit but have no model or part number. thanks
DHPmike is offline   Reply With Quote
Old 11-08-2010, 11:09 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Tie rod ends
Some F body and full size car tie rod ends work. The joint end does not matter. The length does. The length must be short/long enough for adjustments.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-09-2010, 07:14 AM   #3
DHPmike
DHPmike's Avatar
Re: Tie rod ends
In this case the length does matter and it needs to be very short. The stock S-10 tie rods are very long. I need some that are very short and fit the S-10 spindle. Im making a set of notchless tie rods for a guy that works with me. basically I need the ends and Im making the center from DOM tube.
I fugured maybe Nova or early Camaro might work. It may take a day trip to the wrecking yard to solve this mystery.
I know some people make these already so I know its possible.
Old 11-11-2010, 12:54 AM   #4
v8blaze
Re: Tie rod ends
Michigan metal works uses an off the shelf balljoint on his. he has pics of them on myspace, id check them out and see if you find out what they are off of, b/c i doubt he will tell you.
v8blaze is offline   Reply With Quote
Old 11-11-2010, 06:56 AM   #5
DHPmike
DHPmike's Avatar
Re: Tie rod ends
Id rather just do the wrecking yard research. Ill take an S-10 spindle and see what else fits it.
