Old 11-11-2010, 11:11 AM   #1
BardonRedDeath
automatic shifter has play
My automatic shifter on the steering column has alot of play in it example when i am in Drive it drops down to look like it is in 2nd. any suggestions easy fixes for this?
BardonRedDeath is offline   Reply With Quote
Old 11-11-2010, 02:19 PM   #2
white71chevy
white71chevy's Avatar
Re: automatic shifter has play
I'd like to no this also. As mine does the same thing.
71 c10 with a 305. new dd wohoo
1956 chevy bel air hard top with a 327.
1998 honda passport V6 old dd.
white71chevy is offline   Reply With Quote
Old 11-11-2010, 09:07 PM   #3
BardonRedDeath
ttt any answer would be appreciated!
Old 11-11-2010, 09:10 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Its most likely the bushings in the shift lever at the bottom of the column and at the transmission.
dwcsr is offline   Reply With Quote
Old 11-11-2010, 09:36 PM   #5
MT1972cheyenne
MT1972cheyenne's Avatar
If you look at the linkage closely under the truck, you will see the problem. The "bellcrank" (for lack of a better word) wears in a couple of spots, as does the part that rides against the "bellcrank" and attaches to the transmission shift shaft with 1 nut. They are no longer available to buy new, so I took both of mine out and carefully welded up the worn spots, then ground them a bit for a good fit. It made a HUGE difference. I hope that makes sense.
MT1972cheyenne is offline   Reply With Quote
