Old 11-13-2010, 11:25 PM   #1
chev-obsession
chev-obsession's Avatar
under bed gas tank conversion?
What tank is every one using to put the gas tank under the bed? I know they sometimes use the blazer tank, is there anything else?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-13-2010, 11:43 PM   #2
absintheisfun
absintheisfun's Avatar
Re: under bed gas tank conversion?
I used the one that CPP sells...not too happy with it. The fill neck comes out right at the frame rail and in order to route the fill hose, I had to notch the frame rail and run some hose up the inner wheel well. I like the "stealth" look of the fill point, but I'm still bitter about having to notch the frame.
Another point of dislike is how low the tank sits. It almost entirely covers the rear diff cover. I know that there are some Stainless options out there, and custom tanks as well but I don't think I even want to know how much $$$ that costs!
Ricks tanks fabbed up a stainless tank for my Camaro project that is truly a work of art--but I am paying for that one! Since the '63 is my parts runner for now it gets the cheapie parts. Once the Camaro is done, the C10 will get the primo parts as well.
If you want to try Ricks, http://www.rickstanks.com/. Hector is the guy to talk to.
1967 Camaro - Current Project
1963 C10 - Shop Truck (Next Project)
2008 Saturn Sky Redline - Wife's ride
1993 GMC Typhoon - Getaway truck!
absintheisfun is offline   Reply With Quote
Old 11-14-2010, 12:06 AM   #3
vortech71chevy
i saw a thread where a guy used a 69 camaro tank and hid the filler behind the plate. im gonna use a 72 camaro tank i have lying around, ill post up pis once its done...
vortech71chevy is offline   Reply With Quote
Old 11-14-2010, 02:01 AM   #4
Captainfab
60-66 Nut
Check out Lakeroadsters build thread. He used a late 40's early 50's car tank. It worked out very well. There are also 2 board vendors that make aluminum fuel tanks. They can be found in the 'Vendors Marketplace' here on the board.
Old 11-14-2010, 02:13 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Here's an earlier thread with related input, including other links to even more threads:
http://67-72chevytrucks.com/vboard/s...light=gas+tank
Old 11-14-2010, 10:59 AM   #6
Rich 5150 69
Rich 5150 69's Avatar
The `70 camaro tank is 40.5 inches wide, and 7 inches deep, your frame rails are 27.5 inches wide inside measurement, you plan on bolting on below the frame rails...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-14-2010, 11:19 AM   #7
lakeroadster
Yes, these guys are mounting the Camaro tanks under the frame. Here is a link http://67-72chevytrucks.com/vboard/s...ghlight=camaro
Caution... Ranting starts now....
While I applaude creativity, IMO these low hanging tanks that are visible from the back and side of the truck look like an afterthought, not a well engineered and implemented modification.
To each their own, that look is not what I would want after putting in all the effort. This stuff bugs me, like the new vehicles that are being built with gas tanks, mufflers and spare tries hanging down and visible from the back... aarrggghh
If:
- you are running a large rear step bumper the low hang tank isn't as noticeable,
- you run a nice clean roll pan then the low hang tank would be really noticeable,
- you have a longbed vs. shortbed the longbed low hang tank isn't as noticeable.
Even the popular "blazer" style tanks hang pretty darn low, again, IMO
Camaro Tank
Blazer Tanks
49-52 Chevy Passenger car Tank
Install starts with post #8 here: http://67-72chevytrucks.com/vboard/s...d.php?t=363509
lakeroadster is offline   Reply With Quote
Old 11-14-2010, 11:29 AM   #8
Rich 5150 69
I`m with you John, too much tank hanging down, if he wants the rear filler he can use the 1970 challenger or cuda tank or early `65 to 70 mustang which the latter will require some rail trimming to fit.
Old 11-14-2010, 11:39 AM   #9
'63GENIII
'63GENIII's Avatar
If you are running a large rear step bumper the low hang tank isn't as noticeable, if you run a nice clean roll pan then these tanks would be really noticeable. Even the popular "blazer" style tanks hang pretty darn low, again, IMO.[/QUOTE]
I agree. Even on a 4x4 they will hang low. They looked low on the Blazers that they came on. That's been one of the things holding me back from this swap.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-14-2010, 11:59 AM   #10
Rich 5150 69
Gen III go here http://www.quantaproducts.com/ they give measurements for most tanks, the cuda /challenger for `70 /71 fits, although mopar uses 240 ohm senders, if using aftermarket gauges its not a problem, just order the gas gage for a mopar, if using stock gauges you`ll have to convert the gauge or sender. the tank fill is separate, which is a plus if you need to adjust where you want it to come out, you can cut/weld to your liking or order one from another body style mopar.
Old 11-14-2010, 12:10 PM   #11
'63GENIII
'63GENIII's Avatar
Thanks Rich. Bookmarked for after the holidays! Chris
Chris
'63 k15 long step
Old 11-14-2010, 02:11 PM   #12
chev-obsession
wow! there are so many different possibilities! I;m glad i asked about this because i almost bought the blazer gas tank, and now im glad that i didnt1 i really like the early 50's car tank, i just want the filler to be in the bed, does the wood in the bed interfeer with the gas tank? it looks like it might? very cool though
1965 c/10 swb
1969 c/10 lwb
Old 11-14-2010, 02:51 PM   #13
lakeroadster
It does not interfere with the wood, but I notched the rear bed cross sill. And yes you can just install the filler cap in the the wood bed.
Old 11-14-2010, 03:38 PM   #14
chev-obsession
Take a look at my build thread, installing the 49-52 Chevy tank does require some fabricating.
allright ill check it out and now im pretty much set on that tank, i like how you put where you got your parts from!
fabricating is no problem for me
1965 c/10 swb
1969 c/10 lwb
Old 11-14-2010, 03:51 PM   #15
SIR
SIR
SIR's Avatar
you might check out a 60-61 *0rD falcon tank,I had an artical and photos on the set up. it looks like a "drop in" and it doesn't hang way down below the frame rails,and there cheap!...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 11-14-2010, 04:04 PM   #16
lakeroadster
Picture of the aforementioned Falcon install and the thread that it is from:
http://67-72chevytrucks.com/vboard/s...=falcon&page=2
I think this tank is the same as an early Mustang tank except for the filler location.
Old 11-14-2010, 04:22 PM   #17
lakeroadster
And here is an article on installing a '70 Cougar Tank in a '55 series 2 pickup. Not sure this would work on a 64-66 except on a long bed due to panhard bar crossmember location:
http://www.jalopyjournal.com/forum/s...stang+gas+tank
Old 11-03-2021, 09:30 PM   #18
65C10ED
65C10ED's Avatar
Here's a short video of how I installed a 69 Camaro tank in my 65 C10 with the filler located behind the rear license plate.
https://rumble.com/vgbjpv-camaro-gas-tanked-c10.html
65C10ED is offline   Reply With Quote
Old 11-03-2021, 09:46 PM   #19
AcampoDave
AcampoDave's Avatar
I wanted one that wouldn't hang too low so I started a thead a while ago. I did find one I really liked too.
Here's the link http://67-72chevytrucks.com/vboard/s...d.php?t=621177
AcampoDave is offline   Reply With Quote
Old 11-04-2021, 10:28 AM   #20
Chevy Fleetside
Chevy Fleetside's Avatar
I used the universal truck tank from tanksinc.com. it doesn't sit too far under the frame rails. They do have a 90° bend you can use if you want to put a side fill in. I just go through the bed of the truck for now. The only downfall is the tank is only like 16 gallons. I will try and get it under bed picture and post it later.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-04-2021, 12:32 PM   #21
Chevy Fleetside
The first picture is with the camera at bumper level. Does not hang below wrap around bumper. Second picture is phone pointing up from under bumper shows you how far under the frame rails it is. But then again it is only 16 gallons. Third picture is Blazer tank and my other truck. Tucked all the way up to the top of the frame rails. Of course this is with no roll pan or bumper.
Old 11-04-2021, 05:52 PM   #22
vince1
I used one from a CJ5 Jeep. The filler neck comes out the side and I fill it from over the box side. I used a fill assembly from a Dodge truck (auto wreckers). The biggest annoyance for me is that the fuel sending unit is not of the correct ohms and I had to get another gauge, which has since stopped working. The capacity is also probably a little short for some peoples liking.
https://www.gastankdepot.com/1772009...cj-models.html I think this may be the one.
vince1 is offline   Reply With Quote
Old 11-04-2021, 06:03 PM   #23
AcampoDave
AcampoDave's Avatar
Even though I like having the tank out of my cab, I don't like having my spare in the bed.
Old 11-04-2021, 06:19 PM   #24
vince1
For us that still get winter, I think getting the tank outside helps in not keeping the cab so cold. As for the spare tire how about using the vertical bolt in tire mount? I don't know if all the pick ups came with them or not but I don't find it an annoyance at all, or maybe only a bit when cleaning junk from around the tire.
Old 11-04-2021, 11:54 PM   #25
62bagger
62bagger's Avatar
I used a mustang tank from tanks Inc. Its 17 gallons. I would have liked a larger tank but I did not want it to hang below the bumper.
62bagger is offline   Reply With Quote
