Old 11-18-2010, 09:03 AM   #1
remist17
remist17's Avatar
Electric Fan Size help
Well I have built a 383 and started it last night. Was going to break in the cam and brought the RPM up to 2000. The 5 paddle fan that I had secured to the water pump broke sending it into the radiator and destroyng the radiator, shroud, crank pully and water pump.
So the rebuild begins! I am going with electric fans now but not sure what size CFM the truck needs. Can someone advise what size fan I need to run and the best place to purchase them from
1987 Chevy R10, 383 stroker, Comp Cam 280H, Vortec heads, Airgap intake with a Holley 4160.
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 11-18-2010, 05:10 PM   #2
remist17
remist17's Avatar
Re: Electric Fan Size help
Bump for some help... Looking for the CFM need for a v8 motor and a good fair place to purchase.
Support the Troops.
Old 11-19-2010, 09:27 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
I run a cheapie 16" single s-blade fan that I got off ebay and an aluminum shroud. Keeps my 383 cool with the a/c on high in 100F+ ambient temps.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-19-2010, 09:31 AM   #4
remist17
remist17's Avatar
SWB could you advise what make it is? I will try and located something similiar.
Any other suggestions?
Support the Troops.
Old 11-19-2010, 09:40 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
I am running a 383 with electric fans. I chose the dual 11" fans that comes from SPAL. I bought mine off of Summit Racing under the "Be Cool" dual fans identifier. The fans are rated at 2850 CFM each and normally I only have to run one, but it is always nice to have another available if needed. I also run this fan setup on my DD (91 Chevy Silverado with a 5.7 liter engine).
Frank
piecesparts is offline   Reply With Quote
Old 11-19-2010, 10:24 AM   #6
swb85
swb85's Avatar
I'm not sure what brand it is, I got it from seller "skipwhite" on ebay. It came in a plain white box, but it's been in the truck for over 4 years and 35k+ miles and hasn't skipped a beat.
Old 11-19-2010, 11:32 AM   #7
remist17
remist17's Avatar
Well these seem to be less than the ones I have been looking t.
So I guess I dont need the 5000 cfm they are trying to sell me
Support the Troops.
Old 11-19-2010, 03:23 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
I used a grand cherokee fan in the stock shroud keeps my 406 cool on 100* days
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 11-19-2010, 10:37 PM   #9
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
When using electric fans, max is the best. A Mark VIII fan, jeep or Viper fans work the best. Best options include, dual speed or variable (with a speed controller). I rund dual LS1 fans from a 2000 Camaro.
Mark VIII article: http://www.fordmuscle.com/archives/2...cfan/index.php
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-22-2010, 12:45 PM   #10
remist17
remist17's Avatar
ok I will try and see what I can find
Support the Troops.
